Case Mod - In Progress MAC G5 BENCH CASE
Discussion in 'Project Logs' started by arg-ist, 25 Sep 2015.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    MAC G5 BENCH CASE
    As ı said before there are 2 new MAC G5 mods on the table.My first worklog MAC G5 ATX (passive watercooled) is finished. I take final photos.I t is time to begin with a new worklog.
    1-My first worklog was MAC ATX (passive watercooled)
    Link MAC G5 ATX
    http://forums.bit-tech.net/showthread.php?t=279896
    2. This time again a MAC G5 , but as a BENCH CASE.
    3-And my next worklog again a MAC G5 … But this time as a JUMBO MAC G5 = MAC G5 STACKER
    R JUMBO MAC G5
    I want to make a TRILOGY with MAC G5 cases.
    This time ı want to make a different BENCH CASE from this case.
    A combination of aluminum and acrylic.
    I will use this case
    R1
    But ı wll use only back side panel and the four handles of the case
    R 2
    Case tilted
    R 3
    As a bench case there are two ways that we can use.
    1-Handles at front and back panels
    R4
    2-Handles at sides
    I shall use it , this way.
    R 5
    I want to install 2x360 rads in to the bulge of handles. And PSU ,POMP ,HDD etc . in this case
    R 6
    As usally, MB on the top, on a thick plexi, as MB TRAY .that can be opened to back.
    As ı used it at my first BENCH Worklog
    And ı wannt to mount the video card with a 16X riser card extender flex. To prevent the height of the case ,becouse ı wannt to make a flap cover from plexi.(If ı can do it…)
    R6a
  2. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    oh boy cant wait
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    First a recess for rads and rad grils in to the handles , from acrylic. Drawn at corel
    R 7
    And laser cut from 5 mm acrylic
    R 8
    To bend the acrylics, ı made a mold from MDF.
    R 9
    I can bend acrylic using this mold
    R 10
    Acrylic plate on the mold
    R 11
    Acrylic plate fixed to the mold
    R 12
    Heating of acrylic with heat gun.
    R 13
    And bending of softened acrylic
    R 14
    Bended acrylics
    R 15- 16
    Bended acrylic mounted to the case for trial purposes.
    R 17-18-19
    And second side panel bended likewise.
    R 20
    Two side panels are ready
    R 21
    Second side panel mounted too… for trial purposes
    R 22-23
  4. storm-83
    storm-83 Minimodder
    7 Nov 2014
    looks really good :thumb:
  5. Marquee
    22 Jul 2005
    Looks great. Giving me inspiration to start my next project.
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks..
    Maquee come on...
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Four Silverstone case feets mounted to the bottom of the case
    R25
    Next stage is front and back panel
    Made from 3mm thick acrylic a pattern for front and back panel. And mounted to control.
    Resim24
    At front panel ı don t wannt to use a lott of displays. I want to use 2x lcd temp. displays for radiator entries and 2x lcd temp. Display for rad outputs.total 4 LCD displays for temp. And a fan controllerfor fans.
    And some researches for their placement
    R26-27-28-29
    I have tried with different reservoirs EK X3, Bitspower. With 60 mm Radius.
    but I do not like any
    the most appropriate was EK Tube res X3 60 mm
    R38
    but want to keep the cables of PSU.
    Masking could be a solution to it..
    R 39 40 41
    I wanted a different solution
    At last ı decided to use a wider resorvoir 150mm Radius , to make reservoir as essential element.
    I must make a Jumbo reservoir from acrylic tube like this
    R30
    And use reservoir as essential element. of the buttom case like this
    R 31 32 33
    Reservoir with extrem 150mm Radius. Was to big for this case.
    Therefore ı decided to make it with 120 mm Radius
    R 34 35 36 37
    It is time to make a custom Tube reservoir with 120 mm Radius.
