Case Mod - In Progress Mac G5 by Trozic Customs, finished,interior pics
Discussion in 'Project Logs' started by TD_Dizayn, 10 May 2013.
  1. TD_Dizayn
    TD_Dizayn What's a Dremel?
    28 Mar 2012
    you're right,all parts for 10 chanel controler cost me about 7$ :D ,each chanel have 1A power,
    and it works fine.
  2. TD_Dizayn
    28 Mar 2012
    UPDATE
    Fans for HDD cooling.
    I use two 7cm (AMD) fans and painted them in white.
    Fan holder,plastic is from home clock :)
    Home made fan controler
    Making connectors,I use pins from old fans and then solder them
  3. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    That is wicked looking. Its nice to see you are keeping the air duct look through out.
  4. XcOM
    XcOM What's a Dremel?
    3 Jun 2013
    Its surprising how good this mod is looking for being recycled parts.
    Great skills and giving my some ideas
  5. TD_Dizayn
    28 Mar 2012
    Tnx man,I love yor G5 it is amazing :thumb:
    In my country I do not have anywhere to buy plastic panels :duh: ,
    so I decided to use the old parts and everything I found in my garage :dremel: .
    UPDATE
    I start sleeving 24 pin extension with white paracord.
    First I paint extension cable in silver because paracord is little transparent and wires are colorful.
    Leather...
    PSU cover.
    I use carbon vinyl.
  6. TD_Dizayn
    28 Mar 2012
    VU meters
    UPDATE
    I find two VU meters from old HiFi and I set them to measure fan speed and voltage.
    Making some stickers in PS.
  7. TD_Dizayn
    28 Mar 2012
  8. TD_Dizayn
    28 Mar 2012
    UPDATE
    I make cotroler for SMD strip,
    screws for HDD,
    and cover for ram.
  9. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    The progress looks good keep it up.
  10. Cheapskate
    13 May 2007
    This is coming along great.:D There's so much going on, I'm having trouble following it.
  11. TD_Dizayn
    28 Mar 2012
    Thanks guys.
    After a long time update.
    DVD
    Fans
    Fan controler
    Modding lan card
  12. Tangster
    23 May 2009
    Oh boy, that looks good.
  13. TD_Dizayn
    28 Mar 2012
    Thanks :thumb:
    UPDATE
    Instaling smd strip.
    Test.
    And case is almost finished.
  14. TD_Dizayn
    28 Mar 2012
    UPDATE
    Im finished my G5,hope you like it.
  15. hampurista
    hampurista What's a Dremel?
    21 Jan 2013
    Nice one, looks really good. I doubted that the leather and carbon look would work out in the beginning but they did so kudos to you. More even for building an air-cooled rig compared to I think 95% water-cooled G5 rigs.
  16. TD_Dizayn
    28 Mar 2012
    Thanks;)
  17. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    Very well done, TD_Disayn. How about a few pics of the final interior.
  18. TD_Dizayn
    28 Mar 2012
    Thank you,
    here is a few new pics of interior :cooldude:
  19. stefan442
    stefan442 Minimodder
    14 Mar 2011
    just saw this, wouldnt have thought it would look that nice considering the start!
    Nice job man!
