Mac Screen on a PC??
Discussion in 'Hardware' started by Mother-Goose, 29 Jul 2004.
  1. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    :eyebrow:
    Can it be done, i like the super swanky monitors that u get with the new power macs, but i cant use mac's can u by the screen and then use it with a PC?
  2. Ben
    Ben What's a Dremel?
    11 Aug 2003
    yes as fare as i know they use standard connectors (dvi)
    edit:: as long as your graphis card can run 1680 x 1050+ and has Dvi
    link
  3. Mother-Goose
    22 Jul 2004
  4. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    The newest NVidia cards are the only ones certified to work with the 23" I think.
  5. Ben
    11 Aug 2003
    no thats the 30"
    edit:: do not know but the 9800 pro or fx5950, anything higher than that should work well.
    looks like it would run on a 9600pro but do not know how it would cope
  6. Mother-Goose
    22 Jul 2004
    so by the time i can actually afford all the stuff for my new comp next year i should be ok graphic card wise, coolies!!!
    now, would getting thr FX 53 be a bit extreme?? :hip:
  7. sinizterguy
    25 Jul 2002
    Nothing is too extreme if you have the money to blow on it.
    If you don't have the money and don't absolutely need it, then its too much.
  8. Mother-Goose
    22 Jul 2004
    ah well i will have the money by then, lol and i dont wanna have to upgrade too soon after so it should be ok
