Apple Macbook Pro 13" Dock?
Discussion in 'Hardware' started by Tom @ CCL, 13 May 2010.
  1. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    Hey all,
    Just got one of the new MacBook Pro 13" last week and am after a decent dock for it.
    Anyone got any recommendations?
  2. GoodBytes
    20 Jan 2007
    The Apple laptop doesn't support docking stations, you need business level laptops.
    The best you can do, is get a stand (or nothing), and manually attach every cables that you may need, instead of simply sliding the laptop into a connector.
  3. Tom @ CCL
    10 May 2010
    The best one I have seen so far is the Henge dock.
    Just after some personal recommendations really!
  4. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    I was actually going to recomend that one after seeing it on engadget, but it seems you already find it, i've never seen any other kind of docks for macbooks tbh
  5. Tom @ CCL
    10 May 2010
    I would have thought there would be dozens of them available, it is not as though the unibody design is brand new or anything.
  6. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    The problem is. There is no support for a dock from Apples side, so the Mac lacks all form of a "click-in" connector in the bottom.
  7. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    ^ This.
    The Engadget-reviewed one is the most promising I've seen, too. I'd go for that.
  8. Tom @ CCL
    10 May 2010
    I do see your point, but the Henge solution is quite a good option so I am just surprised there are not a few of them about.
    Looks like I will see about getting a Henge in the near future then!
    Cheers for the replies guys.
