Apple Macbook pro or macbook air
Discussion in 'Hardware' started by numanoid, 1 Dec 2021.
  1. numanoid
    numanoid Minimodder
    26 Apr 2009
    Hi guys
    Im wanting to get my daughter a macbook for christmas she wants something that she can send items from her iphone to her macbook and vice versa but i dont know if i should get a macbook pro or a macbook air,need help guys,thank you
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    What's she doing with it?
    numanoid likes this.
  3. andrew8200m
    andrew8200m Modder
    4 May 2009
    The air was just £899 this last week. If that’s all she is after doing you won’t see a difference between it or even the 16” M1 max!
    Performance is incredible, it is silent and the battery is brilliant. The screens are pretty good too!
  4. numanoid
    numanoid Minimodder
    26 Apr 2009
    Just collage work buddy, needs to be able to send stuff from her iphone pro max to the macbook and vice versa buddy
  5. numanoid
    numanoid Minimodder
    26 Apr 2009
    Thank you matey,looking into it,cheers
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Most people just use cloud services for that, which computer or phone you have doesn't really matter in this case either machine will do.
    For example if she uses Office 365 via her education establishment, you could sync via OneDrive as you'd have 5Tb of dsic space free but equally you could use any of the cloud providers like Google Drive etc. If she has iCloud then you can put that on a PC also to sync her phone content to computer.
    Do you know what services she is using?
    Also what sort of size screen will she want, the air might be small for somethings? I would go Air personally, nice bit of kit at reasonable money, but I like small screen laptops and don't have requirements like numpad etc, the larger screen stuff from apple like the pros are another level price wise.
