Case Mod - In Progress Macchiato (Finished February 5)
Discussion in 'Project Logs' started by Kryll, 10 Dec 2012.
  1. Kryll
    Kryll New Member
    11 Jun 2012
    Macchiato - made out of black espresso with some milk. Same color team as in this build, black and brown.
    A long and boring winter ahead, so time for a new project.
    This build will be based on the Bitfenix Prodigy case. A little big case that have room for everything and not to tight to work with.
    The material for this build will be sapele ( a African kind of mahogany). The rest of the case will be covered in plexiglass that I will paint black on the inside.
    All will look similar to one of my older builds, Cream. But in black and better cooling.
    Concept picture of what I have in mind.
    The air vents will be covered with dust filters and mesh and not to be open as in the pictures.
  2. Kryll
    Kryll New Member
    11 Jun 2012
    Started to strip all unnecessary from the case :)
    Last picture show how the case will stand when all is done.
    Some of the frame material sawn and planed.
    Assembled to a L shape
    I have also managed to do some of the corners.
  3. Kryll
    Kryll New Member
    11 Jun 2012
    Working on the frame
  4. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
    This is off to a great looking start :)
  5. AciD_RaiN
    AciD_RaiN New Member
    29 Jul 2012
    Ohh this will be good :D Subscribing to this one for sure :p
  6. Ra6
    Ra6 New Member
    4 Nov 2012
    Nice looking pieces of wood! It's a great combination with the other parts of the mod! ;)
  7. Sn00k3r
    Sn00k3r Member
    7 Apr 2011
    nice craftmanship :D
    subed'
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Subed for more wood..... :X
  9. Ace_finland
    Ace_finland Member
    11 Aug 2012
    nice! keep those pictures coming!
  10. Sissilisko
    Sissilisko New Member
    26 Apr 2012
    what are you planing for the empty space? and nice start :)
  11. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Here aswell? Well it´s looking very very nice kryll!!
  12. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    I like where this is going!
  13. Kryll
    Kryll New Member
    11 Jun 2012
    Thank you all :)
    I'm a attention whore :D
    Sorry for being a bit slow on the updates, here is the latest anyway...
    Did the only real modification an the original case. Drilled a total of 8 holes I the frame :)
    The holes is placed right where the feet/handles are mounted so the Prodigy can be restored to it's original appearance just by unscrew some screws (why should I want to do that??? :))
    Screwed the frame in to place and tested the "hood frame".
    And the bottom part of the frame is done.
    After that it was time to work on the plexi, milling out the vents and bending it in shape
    Well.. It didn't work out.
    At the first try I ended up with a huge crack in the middle of the bent, bended the plastic before it was hot enough ("forgot" to take a picture at that).
    Second try I ended up with a misshaped vent and a small crack.
    On Monday it's the third time, wish me luck :)
  14. KidMod-Southpaw
    28 Sep 2010
    This is my kind of colour scheme! Can't wait for more! :thumb:
  15. k.3nny
    k.3nny Active Member
    27 Jan 2010
    looking verry good already!
  16. Fordy
    Fordy Member
    28 Feb 2010
    Awesome woodsmanship :jawdrop: :dremel: :thumb:
  17. Ch2pa
    Ch2pa New Member
    28 Aug 2012
    Well done sir, this is a very promising start :thumb:
    When you bent the plexi, what did you used to push on it? (and maintain a good curve?)
  18. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    I didnt know acrylic crack when heat bending. Btw, looks like a nice worpshop. Is it yours?
  19. Kryll
    Kryll New Member
    11 Jun 2012
    Just used a flat piece of wood to press with and pulling the plexi.
    Think the problem was that it was not hot enough when I bent it.
    Not my own workshop, but where I work. Almost my own anyway :)
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I really enjoy watching this log. Looks very nice.
