Photos Macro (Warning: High image count)
Discussion in 'Photography, Art & Design' started by Vers, 26 Apr 2010.
  1. Vers
    Vers ...
    23 Oct 2007
    Here are a few recent images from a couple days ago shot using my DIY diffuser.
    1[​IMG]
    2[​IMG]
    Jumper...jumping. A first (and likely last) for me.
    3[​IMG]
    4[​IMG]
    5vhttp://farm5.static.flickr.com/4031/4549569709_a0c0b98ff4_b.jpg
    Black carpenter ant in an entryway
    6[​IMG]
    Very tiny black ant
    7[​IMG]
    Swatted/stunned Eastern carpenter bee...he was asking for it!
    8[​IMG]
    9[​IMG]
    Paper wasp collecting building materials
    10[​IMG]
    11[​IMG]
    An ugly (stacked from two images)
    12[​IMG]
    Another...
    13[​IMG]
    Jaws (Cadelle) in protective mode (stacked from two images)
    14[​IMG]
    15[​IMG]
    16[​IMG]
    17[​IMG]
    Tiny Orchard Orbweaver
    18[​IMG]
    19[​IMG]
    Jumper [Phidippus audax]
    20[​IMG]
    Tiny Wolf spider?
    21[​IMG]
    Eastern Forktail (F)
    22[​IMG]
    Think this may be a newly 'hatched' female.
    23[​IMG]
    And a newly 'hatched' male.
    24[​IMG]
    25[​IMG]
  2. Prime
    Prime What's a Dremel?
    19 Aug 2009
    Spectacular :thumb:
    I love jumping spiders. They look cute :hehe:
  3. stonedsurd
    11 Mar 2009
    I think you're curing my arachnophobia.
    I saw the spider pictures and couldn't help but think how fluffy and cute they looked :p
    Great shots :thumb:
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Fantastic as always, you must have so much patience :D
  5. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Impressive set of shots, very impressive lens collection too, lots of L!
    Are most of these taken on your sigma macro? What sort of rig do you have for adjusting the focus? The depth of field on some of them is minuscule.
    Do you have link for the home made diffuser? I just bought a light ring, funnily enough for taking pictures of LEDs, tried to make small lighting rigs a couple of times but never really had much success.
  6. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    Awesome photo's mate...
    Nice job..
  7. Vers
    Vers ...
    23 Oct 2007
    Appreciated, Fellas :)
    Stone, Jumpers have so much personality, and some even seem to generate expression. It's quite comical shooting them.
    Kev, patience is an important part, but its a non-issue when you love what you're doing.
    Phenoptix, Yes, these were all shot with the Sigma 150 in conjunction with a 1.4x TC and a 36mm tube. I'm not sure what you mean by "What sort of rig do you have for adjusting the focus?" but I use MF, generally with my left hand :) DOF at and past 1:1 becomes very thin--most of these were actually shot at f/13 with a few exceptions. Here are a few quick snaps of my rig with a short description.
    Diffusion panel: Top/Front 9", Depth 9", Bottom/Rear 4.5"
    The diffusion panel is made up of only two elements: A section of plastic from a one gallon water container and a sheet of vellum. The housing is comprised of cardboard lined with tinfoil, clear box tape and gaffer tape.
    Note the large size. With longer working distances comes the need for more light and a larger apparent light source. The larger the light source the softer the light.
  8. phenoptix
    16 Aug 2006
    By rig I meant do you have anything special to adjust the camera's position to move the focus position. I have bit of kit where you can adjust the camera in the x and y so you don't have to use the focusing ring, once you have a focus point. I remembered seeing someone with a heavy wooded set up to do the same thing, also that way any adjustments didn't transfer massive amounts of shake to the camera.
    I have various bits of cheap kit, seems your set up is very professional so I expect we wouldn't have the same problems.
  9. Andersen
    Andersen Brain for hire
    25 Nov 2002
    I'm extremely arachnophobic (screaming and hitting ctlr+f4 even if its a photo on Wikipedia) and kill that eight legged ******* of nature or leave the room very quickly. No problem with jumping spiders though. I'd take one as a pet tbh.
  10. Toxic_Lemon
    Toxic_Lemon What's a Dremel?
    30 Jan 2010
    Man those shots are epic, i wish i had your patience and talent that you have.
  11. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    Vers, excuse my ignorance of Canon stuff, but when you say, Tube, do you mean, extension tube ? Doesn't that not allow auto focus anyway or if it doesn't it hunts ? Or are you using MF out of preference ?
  12. Vers
    Vers ...
    23 Oct 2007
    What you describe sounds like a focus rail. I don't use one, in fact 99% of my macro work is done hand held. I only use a tripod for studio work.
  13. Vers
    Vers ...
    23 Oct 2007
    :thumb: Most definitely--they are great spiders :D
  14. Vers
    Vers ...
    23 Oct 2007
    Appreciated :) Get out and shoot, time and practice make perfect :)
  15. Vers
    Vers ...
    23 Oct 2007
    Yep, Extension tubes. I use the Kenko DG version, which while they allow for AF I don't use it--MF all day long :)
  16. cybergenics
    27 Jun 2009
    How many stops do you lose through the tube ?
  17. Andersen
    25 Nov 2002
    There's just one question. How will two maine coons (getting one next summer, second coming later) and a jumping spider get along?
    I'm thinking "nom".
  18. Vers
    Vers ...
    23 Oct 2007
    There is minimal light loss, specifically in the VF, but not enough to make a noticeable difference. The 1.4x is where I lose a stop.
  19. Vers
    Vers ...
    23 Oct 2007
    Yea, I don't think a cat/spider combo is a healthy one :)
  20. Joey9801
    Joey9801 Eric the Half a Bee
    24 May 2009
    some of those all of those picture are amazing :D
