Modding Macroman could you help or someone else pls
Discussion in 'Modding' started by sboy, 28 May 2002.
  1. sboy
    sboy What's a Dremel?
    6 May 2002
    What size alui knobs did you use on this
    or does anyone else know as there are a few in maplins
  2. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    hmmm looks like my Lian Li....only much, much, better
  3. x24
    x24 What's a Dremel?
    9 May 2002
    Eyeballing, those knobs' diameter go somewhere around half the height of the bay plate.
  4. Fatboy
    Fatboy Bored
    8 Oct 2001
    can be found on maplins , brushed aluminium nobs:
    3 sizes
    YR65V
    YR64U
    YR66W
  5. sboy
    6 May 2002
    Yeah i know this but what size do you think they are
  6. Fatboy
    Fatboy Bored
    8 Oct 2001
    it should say on the site
  7. macroman
    macroman The One
    3 Sep 2001
    They look like the 22mm (YR65V) ones to me ;)
  8. Fatboy
    Fatboy Bored
    8 Oct 2001
    Smallest:
    Diam 15mm
    Height 14mm
    meduim:
    Diam 22mm
    Hieght 14mm
    Biggest:
    Diam 28mm
    height 14mm
  9. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Same as the ones I used ... YR66
  10. sboy
    6 May 2002
    Thanks matey thats all i needed to know:eeek: :lol:
  11. macroman
    macroman The One
    3 Sep 2001
    I beg to differ sir :D
  12. sboy
    6 May 2002
    macroman need help again:cries: how did you measure out your plates front and back one any tips you can give me?;)
    also what size about is the circle's (holes) on the lian li plates
