Electronics Macroman's Rheobus
Discussion in 'Modding' started by Haddy, 23 Feb 2002.
  1. Haddy
    Haddy World Domination
    22 Jan 2002
    now i understand how to do a regular rheobus but how and whatwould i need to do a pushbutton rheobus like macromans in his pc-60 case????
  2. linear
    linear Minimodder
    5 Oct 2001
    It's pretty much a matter of sourcing the parts, I believe.
  3. Bricolo
    Bricolo What's a Dremel?
    22 Feb 2002
    you need a digital potentiometer with a lm317
    i'll post the shematics in a few hours :)
  4. linear
    linear Minimodder
    5 Oct 2001
    Sorry, I totally misread the question. :eek: I thought you were referring to the xBus with the push-on push-off pots. Hence my trivial answer, sorry.
  5. Bricolo
    22 Feb 2002
    sorry, I must go to a friend's now, I don't have the time fot the shematics now
    but this is woh to build one
    use bit-tech's fan regulator's shematics, the one with the lm317
    but instead of the variable resistor, use a digital potentiometer with an up down interface
    and take care that the value of the potentiometer is approx the same as the potentiometer's one
  6. Haddy
    22 Jan 2002
    i reall wanna know where to find the push-on push-off things themself......
  7. Kronus
    Kronus What's a Dremel?
    3 Feb 2002
    same here..i'd rather have the fans on when i want them ect ect.. but i also like the conventiality of just pressing the fan controller in instead of flicking a switch....
  8. Haddy
    22 Jan 2002
    well c from what i read it looks like its a rheobus which means (to my limited electronics knowlege) that it pushes from on and off but all turns to control the voltage....i dunno maybe im wrong but thats what i thought thats y im interested in these things.........
  9. linear
    linear Minimodder
    5 Oct 2001
    I think the original question referred to a digital pot, wherer there's a push button each to turn it up and down. You'll just have to source a digitral pot and build it, but you'll be using a voltage regulator design since a digital pot can't dissipate the power required for a straight rheobus design.
    Ditto with the push-on-push-off pots, you won't get one rated 5W so you'll need to build the regulator design.
  10. kong
    kong cnc-guy
    24 Feb 2002
    Of course you could always bodge one by simply sticking a push switch behind the rheostat, then create an enclosure for the rheostats that will allow them to move back and forth to activate the switches.
    Just call me bodger! (Bloomin' works good though)
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I found a simple digi-pot controller at EDN Access - Digital pot control , a momentary DPDT rocker switch alters the setting.
    Problem now is finding the pot over here. :confused:
