Apple Macs and CDs with jpegs on.
Discussion in 'Tech Support' started by Herbicide, 24 Apr 2009.
  1. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Not 'Picture CDs'. (there is, alas, a difference.)
    A CD with jpegs on was [burned|burnt] on a windows box as a data CD. There is normally nothing wrong with this, as everything we have reads them.
    This was then handed to someone with a Mac. (other than it was purchased in 2008, I know nothing about it)
    The mac fails to read the disc:
    Research ensues.
    The bold bit is the problem, I suspect.
    Is there a simple and/or quick way of getting the Mac to read 'ordinary' data CDs?
    NB: I don't have access to the(or, any) Mac, so am restricted to emailing advice.
  2. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Never burnt Anything to a Data DVD, so....
    There should be no problem, as OS X can read any type of file system, and every Mac released in '08 had a DVD Drive. If they can be read in XP/Vista, then there should be no problem at all, has the specific disc been used in another PC and it Worked?
    Last thing i suggest is USB Flash Drives :D
