Modding magic foil... has it vanished?
Discussion in 'Modding' started by mobius9, 9 Jun 2005.
  1. mobius9
    mobius9 Minimodder
    4 May 2004
    I've decided to start modding another computer and had an idea that could incorperate some magic foil... however, after a trillion google searches I've been able to uncover absolutely nothing related to the actual product, only the fact that it has been used on some cars.
    its seen at the top of the page here: http://www.bit-tech.net/bits/2005/05/10/cebit_2005_part_4/3.html
    I asked about it in the CeBit thread, but I didn't get a response. Maby someone in here knows. It seems like this magic foil stuff doesn't exist outside of the cebit article.
  2. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    I think they used something like that in the Maybach (car). I think it might have something to do with electrochromic (or electrochromatic) glass.
    Think of the the reaction lenses you get for glasses (photochromic), which re-act to light. The Maybach used windows that were electrochromic so you can adjust how much light they let through by somehow chnaging the electricity passing through it.
  3. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    ive seen this stuff on afew fancy holiday homes for large bathroom windows, so its deffinatly out there, somewhere :)
  4. Guest-6374
    Guest-6374 Guest
    On an episode of Batman: The Animated Series, an inventor developed a similar technology with fabric. The material bent light when an electric charge was applied, but caused severe tissue damage in the process so the project was abandoned. His assistant made a bodysuit out of the stuff and went on an invisible crime-spree, but eventually went kind of crazy from the effects of the suit.
    If you find this stuff, don't wrap your body in it, or Batman will take you down.
  5. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    This isn't exactly like that batman fabric, if he makes clothes out of this stuff, it's gonna be more like "the emperors new clothes"
  6. TX297
    TX297 Hey guys have you heard of seenly?
    28 Oct 2003
    It's essentially 2 plates of glass with a liquid crystal sheet sandwiched between them. Apply an electrical charge and it goes opaque. "Magic foil" was just a flashy CeBit name but its more common name is liquid crystal glass. You'll be able to find a lot more results that way.
    Hope this helps,
    -TX297
    Edit: Closer inspection [Read: Google] says that the charge makes it transparent due to the liquid crystals lining up (Source)
  7. mobius9
    mobius9 Minimodder
    4 May 2004
    thanks for the info :D
    looking closer, it appears that site links to a manufacturer (Saint Gobain?), however, even their tiny sample is riddiculusly expensive - http://www.sggprivalite.com/en/echanti/echanti_fr.html
    Judging by their display it seemed to me like this magic foil company was geared more towards the common consumer. I'll keep looking in the mean time I guess.
  8. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    contact whoever took those pics of the magic foil, then see if they can get you a better quality version of the picture so you can read the bottom of the display where their website is (spent about a hour last nite trying with no avail)
  9. mobius9
    mobius9 Minimodder
    4 May 2004
    great idea!
    done, emailed the article writer dave williams just minutes ago.
  10. vetlel
    vetlel What's a Dremel?
    7 Apr 2004
    Seen this applied to glass panes around the front door. The effect is great when someone rings the doorbeel, and you hit the switch....
    It is crazy expensive, though. What i could get out of these people, it was over 100,000 euros for the 18 square metres they had. ( Do your math, boy ;-) )
  11. CREDO
    CREDO What's a Dremel?
    18 Jul 2004
    You will get better results if you search for "privacy glass"
