Guide MagLite Mod 2
Discussion in 'Modding' started by Mondak, 8 Apr 2004.
  1. setishock
    setishock What's a Dremel?
    10 Feb 2005
    I agree...
    You're right about that. It's kinda like I could by a case for my p4 but would rather take what I have and mod the H*** out of it. Party on...
  2. duffman123456789
    duffman123456789 What's a Dremel?
    26 Jan 2005
  3. Seth
    Seth What's a Dremel?
    14 Mar 2002
    okay so I ordered the kit for the mini mag light. yup :)
  4. Machine
    Machine What's a Dremel?
    27 May 2004
    im thingking on mod my mini mag-lite, using 1 1200mcd white LED, thers no room for more than 1, even whit 1 needs to be "hard moded", i wonder if its worth, i cant find how much light it produces in "MCDs" to calculate if its worth or not.
    im in mexico so its nerly imposible to grab some luxeon stuff.
    not shure if its gona work... but I MUST MOD :D
  5. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Really good. I have to try the same for other torches.
  6. Ericspda
    Ericspda What's a Dremel?
    5 Apr 2005
    Luxeons are amazing...
    Screw the three led's I put 32 led's in my 3D mag and was disapointed with the results. So... I decided to go with 4 of the 3 watt luxeon stars (white colored) and run them dirrect drive to make 350+ lumens of blistering led light... But the luxeons arent here yet... I'll keep you updated when I get them in and installed! :clap:
  7. rick
    rick What's a Dremel?
    4 Mar 2005
  8. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    You could try rswww.com. They sell all kind of luxeons.
  9. jonesie
    jonesie What's a Dremel?
    24 Nov 2003
    I second that. I have a most bodacious 1W red luxeon LED which will end up on my bike when I have the time...
  10. Neo4
    Neo4 What's a Dremel?
    15 Oct 2004
    good idea :D :naughty:
  11. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    The blue thing isn't a resistor, it's just there to help support the filament.
    A lightbulb is essentially a resistor in and of itself. It simply heats up to the point where it incandesces.
  12. Alekin
    Alekin Minimodder
    27 Aug 2002
    I got one of these to swap for the 11000 mcd one in my keychain light, i wouldnt reccomend staring into it..
    Alex
  13. d0z
    d0z Minimodder
    1 Apr 2005
    LOL bet its not as bright as a standard lamp in one of those :) fun anyway
  14. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    I bought a set of 10 x 20Cd 5mm on ebay, replaced the LED in all my keychain lights, mostly to get a better pattern, the old ones had huge hotspots.
  15. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    just for some info, while I was out in South Africa, browsing one of their adventure shops (complete with its own climbing wall, running maching, and torch testing cave) I noticed an off the shelf conversion kit for the maglight AA. It replaced the reflector too, I was going to get one.. but I decided against it for some reason :rolleyes:
    -J
  16. SteakTheMooCow
    SteakTheMooCow What's a Dremel?
    12 May 2005
    Believe it or not, I'm actually going to do it to several torches.
