Build Advice Magnetic screw drivers
Discussion in 'Hardware' started by Cus_de_Sparta65, 2 Aug 2010.
  1. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    Do they have enough magnetic force to damage a motherboard?
    I am having a problem getting my hand in to a couple of screws on my board and one of these things would come in very handy if I thought I could get away with using one. What is the general consensus on this?
    Thanks, Cus
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  3. Jipa
    5 Feb 2004
    I've used magnetic screw driver for the last 8 years and nothing has gone wrong so far. I'm now very much upset as my favorite screw driver has forgot it's supposed to be magnetic and no longer keeps the screws up.
  4. capnPedro
    11 Apr 2007
    Rub a strong (neodymium/rare earth, preferably) magnet along it, in one direction only.
  5. Guest-16
    Guest-16 Guest
    This ^^ make sure you do larger arm loops so the induced magnetic field puts all the little iron/chrome cores in one direction only :)
    Magnetic screwdriver tips Cheesecake!
  6. Jipa
    5 Feb 2004
    Yeah I've meant to do that for ages, but it's not like I would stop building the rig just because the magnet tip doesn't work, and after that I always just forget about it :) Might get it done now, though ->
  7. Jipa
    5 Feb 2004
    Yeah I used a magnet taken from a HDD and it worked just fine. There are also tools for magnetizing and demagnetizing tools, but dunno if they work any better.
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I've been using a long one for years, I'd be lost without it...
    (oooh-errrr missus):naughty:
  9. Cus_de_Sparta65
    24 Apr 2009
    Thanks guy that's great to know. Should make things a good bit easier
    Cus
