Not sure if this should be here or in the modding section. I am looking for the above. My current case (see sig) has eight small screws just to remove the side panel and although I do have magnetic screwdrivers I would like to use my cordless but seem unable to find a set of magnetic bits. Anyone point me in the right direction?
You won't find magnetic bits i don't think. What i've got is a set of bits with a magnetic bit holder, which you can can also get separately.
I have these They're excellent, and are still magnetic after 3-4 years. I recommended them to my dad and brother and they each have a set aswell now. I don't put that much store by ratchet drivers, but thats a personal choice. EDIT: I THINK those are the ones I have which are magnetic. These ones are and I think this is just the smaller set.
Not sure if this fits the bill. http://www.ebay.co.uk/itm/DeWALT-DT...Home_Garden_PowerTools_SM&hash=item19d3e1bc21
http://www.powertoolsdirect.com/wer...ver-7pc?utm_source=google&utm_medium=merchant This is my daily screwdriver, I use it alot. It has a big magnet in it, to not only hold the bit in, but to make it magnetic. It's a great screwdriver. I bought mine from a tool shop for about 50 quid but its much cheaper online. even at 50 quid I think it's great. Misread your original post. I have a ryobi bit holder, that means you can use conventional short bits in the drill, means faster changing etc. that has a massive magnet in it too i'll try find a link...
