Scratch Build – Complete ⭐ Mahogany Desk by Husky Bongs [Build of the Year 2018, FINISHED]
Discussion in 'Project Logs' started by Huskybongs, 21 Feb 2017.
  1. Huskybongs
    Huskybongs Minimodder
    11 Feb 2017
    Well here we go, the legs have been redone. They now have a more smooth and round shape at the upper part.
    Also increased the surface area and therefor strengthened the structure with about 150% more surface area.
    Obviously the legs will get sanded down and chromed.
    Time to get that screen onto this table then :)
    Screenholder getting bored and threaded
    Using a 65 mm thick shaftsteel to hold the screen in place
    Trown in place
    Tried to get the shape of the screen emulated and keep the same curvature of the wood
    And mounted in place!
    It's a heavy piece now:)
    Testfitting the back wood panel.
    Next up is sanding and getting back some of the things from chrome
    Mr_Mistoffelees and _Prometheus_ like this.
  2. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
  3. Cheapskate
    13 May 2007
    Bond-villain level desk. You just need a 1500 square foot, all-white room to put it in.
  4. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Don't forget the white, long-haired cat.
  5. storm-83
    storm-83 Minimodder
    7 Nov 2014
    just need to locate an active volcano for the lair...
    Mr_Mistoffelees likes this.
  6. Huskybongs
    11 Feb 2017
    Thanks for the kind comments!
    Time to do a small update. Getting my chromeparts back the 17th of marsh
    Got my cableholders back from powder coating. Each hole holds 6 MDPC 16 gauge wires and the bigger hole on the righthand side keeps 5 satadata cables.
    Had to make a truly wooden pc to do the cables for the motherboard without ripping out my motherboard in my current pc
    Got a few layers of the key as well to keep the grease and dirt of my fingers away from the wood. The wood is Flaming Birch
    And here's my lamp that will be in the same room as my desk. Just for the luls
    Just started with this and it's not really a priority but if anyone wanna make a lamp here's 1 way to do it :)
  7. _Prometheus_
    2 Jul 2017
    What it, John Silver's leg? :jawdrop:
  8. Huskybongs
    11 Feb 2017
    Tommorow assembly starts. I got my 27 chromed parts home. FINALLY :)
    Let the games begin :)
  9. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    I'm loving the curved monitor mount. Fits perfectly. :thumb:
  10. Huskybongs
    11 Feb 2017
    It is time then. Second to last assembly. This time every single thing will be built into the table with the exception of putting in the water. Then disassembly one final time prep the parts and go to town and hope the end result was worth it.
    With that being said here we go.
    I just love how nickel plating looks and feels. I had to clean them up a bit with window cleaner but they were looking fantastic in general
    Starting from scratch again pretty much :)
    1 LEG!
    Had to change the type of bolt for aesthetic reasons
    2 legs now and some interior panels :)
    Time for the radiator grills :)
    Portside
    And Starboard
    Installing the big ones
    With the special fasteners
    Also put in a bit of a cheat to make sure they didn't sag at all. Screw wont be visible
    Key mechanism installed
    Had to cut a hole out of the back panel to feed motherboard cables to the screen etc. This won't be visible either
    Painted the reinforcement
    All chromed parts in place
    Key in place as well as the usb/audio plate also that nickel plated. Key as previously made from flaming birch. 5 or 6 layers of 2 component varnish to not stain the wood.
    I like the color scheme
    Monitor back on with the glass
    A lot of photos. Outside is pretty much finished except the wood needs to get that nanosanding done to gloss it up a bit more
    Made a quick video so you can get a better 3d view :D
    _Prometheus_ likes this.
  11. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    Oooooohh SHINY :cooldude:
  12. _Prometheus_
    2 Jul 2017
    This present work of art.:thumb:
  13. Huskybongs
    11 Feb 2017
    For those who liked the hinges here's how they ended up, I'm pretty pleased with them
    Cheapskate likes this.
  14. Cheapskate
    13 May 2007
    The chromer soaked those forever. :lol:
  15. Huskybongs
    11 Feb 2017
    Is that bad?
  16. Cheapskate
    13 May 2007
  17. kim
    kim hardware addict
    10 Jan 2016
    I could guess from the start that you are a perfectionist :wallbash: , and the result is outstanding like I could expect :clap::clap::clap: just fantastic :jawdrop:, it only miss the hardware now :grin:
  18. CAF PCs
    CAF PCs Custom PCs
    11 Mar 2018
    It's wonderful just don't touch
  19. Huskybongs
    11 Feb 2017
    Time for a small update. Parts will start to get installed tommorow :)
    Anyways let's get going, repainted and extended the black to now have any wood show in bad places from the outside
    We made a part for the ethernet and power cable. This way you can easily connect and disconnect the cables with 4x m8 bolts. Obviously this gets powdercoated too
    This will hold a lot of weight if need be. No chance of power cable coming loose
    Pumps arrived, remade the stands for them as well. You'll see how they're mounted very soon (Mainframe m7 )
    Hinges mounted
    Love how it reflects everything :)
    Testing the 2 component epoxy glue on some other glass. Supposedly an area of 56 square centimeters should hold 7000kg of tension force.
    Protecting the wood and hinges from the glue if we get it wrong and use too much. I recommend this specific frozen pizza package for this ;)
    Wide shot with the hinges in. No picture with the glass glued because i'll let it cure overnight just to make sure
  20. Cheapskate
    13 May 2007
    I think you can remove "Aspiring custom PC builder" from your signature. You've put yourself in elite status with this.
    :worried: Just don't spray paint it gold at the last hour.
    ifohancroft and cobalt6700 like this.
