Windows Make icon text dissapear?
Discussion in 'Software' started by Langer, 2 Feb 2005.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    I want a way to make the text underneath my desktop icons dissapear. But I want the rest of my icons' lables to remain. Is this possible, and if so how can I do it?
  2. Zanbee
    Zanbee What's a Dremel?
    25 Jan 2005
    You can try to rename them with ALT+0160
    works for me
  3. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Pfft, File, rename, spacebar, enter.
    rinse, repeat.
    - H.
  4. Totem
    Totem What's a Dremel?
    19 Apr 2004
    alt + 0160 works just as well. might need to have the correct keyboard settings tho? language?
  5. B.Psycho8
    B.Psycho8 What's a Dremel?
    8 Aug 2004
    anyway to do this on recyclebin?
  6. Lowsidex2
    Lowsidex2 Minimodder
    29 Sep 2003
    An alternative is Ultimate Wallpaper Changer. It doesn't remove the text tag but it does make the background transparent. The program is free.
    Before and After.
  7. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    This worked for me.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Or XSetUp will do it without having to find all the weird keys.
    So does XP?
  9. Lowsidex2
    29 Sep 2003
    oh... I run 2k, didn't know that.
  10. tk421
    tk421 Idiot.
    15 Jan 2002
    who needs icons? bleh.
  11. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    My icons grow when I click on them!! :D :lol:
    IIRC there is a setting right with in windows to disable the text. Ill do some diggin to find it.
