Make my day: LianLi V1000b (56k beware)
Discussion in 'Project Logs' started by koegsmk, 24 Jan 2005.
  1. koegsmk
    koegsmk What's a Dremel?
    31 Aug 2004
    So here is another LianLi V1000b.
    I am working on this machine for some time now.
    Some minor mods already have been done.
    Ripped the hardware out of my old case: (some parts have been changed)
    My brandnew V1000b with floppy, swap-drive and dvd/rw installed:
    Drilled a hole for better cable-routing:
    First test wether everything fits (old vga-cooler, sata-drives are removed now):
    This will be the frontplate for my 4x20 text-lcd:
  2. koegsmk
    31 Aug 2004
    Update !!!!
    Some new hardware but still a "before" shot:
    A tight fit with the Zalman NB-Cooler and the PoV GF6800:
    Top Blowhole 120mm:
    Rear "grill" removed and a radiator faceplate installed:
    Top Fan installed:
  3. SMOVE
    SMOVE What's a Dremel?
    17 Apr 2004
    looks good so far :)
  4. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    Switch your blowhole grills, the one on the rear fan looks much better than that generic bullseye looking one.
  5. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Is it just me or is that a massive HSF you've got on there?
    I like this new Lian-Li case a lot, and it seems like it's the general consensus: there are several projects going on right now using this case.
    Good luck finishing this up. :thumb:
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Agree. Change 'em.
    Remember: It's the details makin' the whole look perfect. o_O Whatever... I like what I've seen 'till now. :hip:
  7. koegsmk
    31 Aug 2004
    The HSF is a Thermalright XP-120 cooling a A64 3400+.
    You might be right that the rear fan grill looks better, but i like the look of the top fan grill and how it comes out.
    Some more shots:
    Everything installed:
    Nightshot 1:
    Nightshot 2:
  8. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    sweet :naughty: luv lian li
  9. MenloR
    MenloR What's a Dremel?
    31 Dec 2004
    why fangrill on your cpu fan?
    if no cables hanging around there is no harm. maybe remove it, it must me nices like that.
    and good work :D
  10. koegsmk
    31 Aug 2004
    Well, there is really no need for the fan grill on the cpu-fan, but i think it looks a better than the plain fan.
    Tomorrow i will shoot some fotos of my modded Zalman fan-controller.
  11. koegsmk
    31 Aug 2004
    Small update, added the edge protection: (klick for big)
    Next: side-panel window
  12. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    It´s looking great!! I love the "businessman-style".. And the leds are good when they are only one color.. I dont like those uv-shufflebuffles..
  13. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Looking good there mate!
    Can't wait to see finish result. :).
    Rob.
  14. koegsmk
    31 Aug 2004
    Small update, more updates this evening (CET):
    Plexi-Cover for the hole in the middle-section:
    klick for big
  15. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Is the top fan intentionally intake?
  16. koegsmk
    31 Aug 2004
    Yes, intentionally didn´t correct my mistake. :D
    Waiting for the replacement fan which will be here in a day or two.
  17. ouija
    10 Nov 2002
    I'll let you off :D
  18. koegsmk
    31 Aug 2004
    Well, fans finally arrived.
    Got some aluminium fans with led-lights instead of the plastic ones for free, because the ordered fans were out of stock.
    BUT my motherboard died somehow. Either it stucks before the memory test or none of the USB-ports will work.
    Until i will get an replacement i will use an Asus K8V SE, which i will have to buy tomorrow.
    So no pics for today. Sorry. :sigh:
