Electronics Make my own adjustable 12v flasher?
Discussion in 'Modding' started by scoob8000, 16 Apr 2007.
  1. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    I tried without any luck to find an adjustable flasher for my car, so how about making my own?
    I currently use a 2 prong flasher, one side is +12 with the turn signal is on, and the other side feeds the lamps.
    I want to be able to adjust the flash rate anywhere from half a second to several seconds.
    My googling turns up automotive relays and 555 timers, any pointers? :)
  2. 2JSC
    2JSC What's a Dremel?
    14 Dec 2006
  3. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    This is probably a language difference but I cant work out what youre asking about. I think youre talking about variable flash rate indicators (turn signals) in which case youre on the right track with the 555 timers but id be thinking mosfets rather than relays.
    The 555 circuit youre after is called an astable and although most circuit diagrams on the net wont show it the 555 timer has an enable input that you would wire up to the input signal. A search for the 555 datasheet would be a good starting point if you want to read up about it alternativly there are lots of sites on the net that will explain the 555 timer and how to use it.
    Moriquendi
  4. scoob8000
    17 Feb 2002
    2JSC,
    That's exactally what I'm after. But it's hard to justify spending $40 on something I can probably build with $10 worth of parts from Radioshack and learn something in the process.
    The reason I want to do this is; I've installed sequential tail lights and 60 flashes per minute doesn't give them time to sequence fully. I need about an extra half of a second.
    Basically I just need something that will operate a 12v relay at 60 times per minute with a little adjustment. I can make it work from there, it's getting to this point I'm unsure about.
  5. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    A 1Hz 555 astable would do the trick, wire the output to the relay. Chuck a diode to counteract the back emf and your good to go, something like this:
    http://www.fast-files.com/getfile.aspx?file=1881
    depending on the relay you might want to put a transistor or mosfet between that and the output of the 555.
  6. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    This might be what you need. You will need to modify it a bit to get the timing down to 1 second.
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    With auto lighting one side of the bulb-holder is often grounded to chassis so you need to watch that when picking a semiconductor switching device. Relays may be crude but they're more idiot-proof. ;)
  8. Moriquendi
    3 Nov 2005
    Thats true but I was thinking of the lifespan, when ever someone talks about hooking a relay up to an oscillator I wonder just how long it will last. Could always use a P-channel fet. I take the point about robustness though.
    Moriquendi
  9. Xiachunyi
    3 Nov 2003
  10. scoob8000
    17 Feb 2002
    That would be a perfect starting point, and the price is right.
    I'm afraid of completely breaking it trying to slow it down more than 2.5 seconds. I assume it would be done by just adding another resistor inline with the one pot?
  11. Xiachunyi
    3 Nov 2003
    To the RC portion of the circuit, you will need to either exchange the resistor for one of smaller value or placing a resistor in parallel to the resistor. You can also exchange the timing capacitor for one of lower value as well but it is up to you.
    It is a little hard to tell from the picture where the timing resistor may lie. I will have to see the back of the board to be sure.
  12. Moriquendi
    3 Nov 2005
    They're just as delicate as a discrete mosfet but much more expensive unfortunatly.
    Moriquendi
  13. scoob8000
    17 Feb 2002
    Too bad we can't see the back.. I did find this better picture.. Looks like all 3 resistors are the same?
    If it's going to be that easy to adjust, I think I'll order one. It'll be a learning experience for a electronics newb like me.
  14. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    dude just use my circuit, if you want adjustment just swap out the 3.9k resistor for a 5k pot and adjust until suited
