Modding make ur own heatpipes
Discussion in 'Modding' started by bobtheangryflower, 6 Jan 2009.
  1. bobtheangryflower
    bobtheangryflower lalala
    29 Oct 2007
    well i wanted to make my own heatpipes but problem i run into is
    exactly how im gonna vacuum the air out and fill them with the liquid
    my idea is
    create a vacuum chamber using a shopvac with gloves like a hermatic bubble(bubble boy)
    and do it all in there
    but seems like may take more work but seems like best way to get air out and keep out
    anyone have any better ideas
    this will be part of a laptop cooling mod im doing
    all ideas welcome
  2. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    do heatpipes have liquid in them?
    is it something like liquid cooling? because usually when a liquid enters the tubing, the air exits into the atmosphere.
    you could always try using a vacuum pump. they are use in the H VAC area. basically you braze the pipe with two valves (one at each end) vacuum through one side, then let the liquid run through the other valve.
  3. 731|\|37
    731|\|37 ESD Engineer in Training
    5 Sep 2004
    A shop vac may be a dead end unless you can solve a few problems. I don't see them as having enough suction to give you a good vacuum (then again I don't know what you need for a heatpipe). Furthermore they tend to be air cooled and that air that cools them is that which they suck through themselves. Upshot being that I think if you try it with a shop vac you'll wind up with a less than idea vacuum chamber and a burned out motor.
    You might try and find a pump dedicated to giving these sorts of negative pressures and use that though.
  4. FrooP
    FrooP can I eat this?
    24 Oct 2007
    it does work, but not with a vac cleaner, you need to seal one end of the pipe, put it into something boiling (needs to be hotter than water, eg frenchfries maker with boiling oil ~190°C )
    oh yeah, the water needs to be inside the pipe already (destilled water works best) then, boil it so you can see the steam going out of the open end of the pipe, then seal it with a copper cone and remove it emediatly from the hot oil, then you just have to solder it so it sits nice on your heatpipe
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A vacuum cleaner doesn't create anything close to a vacuum. A typical vac will reduce normal pressure by only 20%, so 80% of the air is still in your pipe.
    You can buy ready-made heatpipes.
  6. headala
    headala What's a Dremel?
    9 Oct 2005
    Why do you need to make your own? Tons of them on ebay, taobao, etc.
  7. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm making my own with froop's design. Yeah, they work, but they're gravity limited.
  8. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    If you can get a proper valve, the necessary amount of vacuum can be easily created with a medicine syringe. Other small pistons work just as well.
