Planning Make your own GPU Waterblock [ HELP ]
Discussion in 'Modding' started by vreas, 14 Apr 2010.
  1. vreas
    vreas What's a Dremel?
    22 Feb 2010
    Hi! Look at the topic name :)
    Ive allways been wondering how to make your own waterblock, for mobo or for your gpu or cpu.
    I take any help i can get, from program, how to get the right dimension etc.
    All infromation to make a waterblock.
    Regards vreas
  2. Cheapskate
    13 May 2007
    That's a little too vague. There's a lot of ways to do it. What tools and materials do you have?
    Also WHAT GPU/CPU?
  3. vreas
    22 Feb 2010
    I mean in general. Whats the procces? Where do you start? What do you need to have before you can start etc?
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    sorry members club information only, come back once you've learnt to accurately Google.
  5. _-..zKiLLA..-_
    _-..zKiLLA..-_ What's a Dremel?
    8 Jan 2008
  6. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    yes, learn to google.
    look at what is out there and what they are made of.
    Learn to use CNC.
    Use google to figure out what CNC means.
  7. Burnout21
    9 Sep 2005
  8. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Please remind me again why you need cnc to make waterblocks?
  9. Attila
    Attila still thinking....
    22 Feb 2008
  10. nlancaster
    21 Dec 2009
    Well i guess you don't have to use CNC.
    But it will get you a better fitting block with more cooling area.
  11. vreas
    22 Feb 2010
    Only 2 helped me, thanks. And yes, i tried to google but no result, so i came here.
  12. Javerh
    5 Sep 2006
    Better fitting depends on how you can use proper correction factors to modify the dimensional tolerances and how the machine can handle the geometrical tolerances. Most manual machines I've seen do a better job at that than hobby-level routers.
  13. Burnout21
    9 Sep 2005
    WTF, tried google and not found anything?
    whats this?
    http://www.google.co.uk/#hl=en&sour...=&oq=DIY+waterbl&gs_rfai=&fp=23e9d7872b349109
    whole page of information.
    Too start out trying to make a full cover Graphics cooler would be a little bold for someone who hasn't got a clue where to start.
    Biggest problem now, is the fact that a decent waterblock made by EK, danger den and other such names can be purchased dirt cheap off ebay for less than buying the materials and tools required to make a waterblock.
    Not saying not to do it, its all fun but potentially a waste of hard earned cash if its not completed
  14. nlancaster
    21 Dec 2009
    lol, i didnt say anything about a hobby level router to make a waterblock. I meant a big commercial quality capable CNC mill.
    And yes part of knowing how to use CNC is knowing your machine and what it, and you, are capable of.
  15. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    There really isn't a need for a CNC to make a very basic pin matrix (ala GTZ/XT like) water block. All you really need is a steady hand and a Dremal with a reinforced cutting disks.
    That's one I made a few weeks ago just cause I was bored and had a 6' bar of 1/4" Aluminum to play with :D. And cause my sisters she wanted her "new" (my old Q6600) PC silent (had a 120mm Kaze on it lol) and I didn't feel like spending $200+ for a good WCing loop. Total cost with pump,etc is ~$45-50. Leak tested over last week end and no leaks so far. Yes, I realized it's mixed metals, so I'll be using 25-30% EG mix. Will post results later, but a similar block I did managed to get me to 3.8Ghz on a E2180: http://hwbot.org/community/submission/888121_shadow703793_cpu_z_core_2_e2180_2.0ghz_3800_mhz
    At 1.72v temps maxed out at ~75-85C.
    Currently working on a 3D Matrix water block, works quite well according to CFD sims, but I seriously doubt it is possible to make this block economically due to complexity,etc.
    Off to go and finish home work for AP Microecon.
  16. Mach
    Mach What's a Dremel?
    30 Jul 2008
  17. abezors
    abezors Lurking since '08
    21 Apr 2010
