Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. Erik
    Erik What's a Dremel?
    8 Oct 2007
    Sorry, I have it running on Vista 32bit.
  2. anego
    anego What's a Dremel?
    2 Nov 2008
  3. Scorpia
    Scorpia What's a Dremel?
    17 Jul 2006
    Vista 64 bit is working fine. Ihave had it running on my PC at home for months
    as far as i remember the latest .inf file from microchip works fine with vista 64bit.
    otherwise the link i posted earlier in the thread worked as well from memory.
    If these dont work for you let me know and ill find the .inf file im using and post it somewhere
    Scorpia
  4. CaesarC
    CaesarC What's a Dremel?
    5 Apr 2006
    Scorpia, please post them!
    I have tried the official 2.3 version from Microchip but it doesn't work. I have a modified version of the code and lost the sources - made a custom graphic lcd - displaying text and/or graphics.
    If your INF can help it will save me a lot of re-coding.
    Thanks!
  5. SimonSoft81
    SimonSoft81 What's a Dremel?
    7 Nov 2008
    I don't know why but every time i try to open the pcbs image i see all with a smaller resolution. And are incomprehensible. Could someone send me the fist circuit scheme and the pcb by email?
    simonsoft81 AT hotmail DOT com
    Tnx to all
  6. anego
    2 Nov 2008
  7. anego
    2 Nov 2008
    hi
    I read in the post that you can add a splash screen to lcd2usd
    you can sent me a modified hex file or better the source code!
    thx
  8. Scorpia
    17 Jul 2006
    try both of the files listed on the link from this post.
    Post 261
    if that doesnt work then please can you post what is happening. ie is it giving error messages etc.
    Scorpia
  9. CaesarC
    5 Apr 2006
    Thanks, have tried both of them a big while ago, none worked, they put out some error that the hardware could not start. The error was the standard one that everyone got, something with code 10 if I remember correctly.
    Sadly I lost the sources and can not recompile using the new 2.3 version. The original project used microchip's 1.3 cdc release.
    In the mean time I took out the same project made for a serial port and just fitted a FTDI chip there but the speed isn't so great as with 18F2550.
  10. brownbear426
    brownbear426 What's a Dremel?
    25 Nov 2008
    Eric
    can you email me the 5 button code you made
    brownbear426(@)gmail(dot)com
    thankx
  11. Erik
    8 Oct 2007
    It will be a few days...I just got the dreaded Blue Screen of Death on my Vista box...which is where the source code is (of course). Once I get that sorted out I will send it to you.
  12. Schrammy
    Schrammy What's a Dremel?
    19 Nov 2008
    ch424 I send you a PM with my emailadress and a request for the source code.
    Could you please send it to me?
    Thanks in advance!
  13. sicone
    sicone What's a Dremel?
    6 Oct 2004
    Would somebody be able to send me a hex file as well please (preferably for 18f4550, but I'm sure with google's help I can figure out how to modify it)
  14. decayed.cell
    decayed.cell What's a Dremel?
    22 Dec 2008
    First post sorry just wondering is this compatible with CrystalControl 2 software and will you be making a controller compatible with Graphic displays with controllers such as KS0108? Thanks
  15. decayed.cell
    22 Dec 2008
    Seems to be one for the KS0108 here
  16. jng
    jng What's a Dremel?
    28 Dec 2008
    Hi, I have a PIC18F2455.
    It has different amount of FLASH, for these reason the code must be adapted to this device.
    Is there any HEX to this device for?
    Can you send me a copy of source code? (I can modify it for 18F2455)
    Thanks a lot.
    PD:Sorry for my English.
  17. unkleblacky
    unkleblacky What's a Dremel?
    5 Dec 2008
    looks like a quality bit of kit, have to get the skills to make it
  18. st1f1
    st1f1 What's a Dremel?
    20 Jan 2009
    i hope i'm not bumping this thread=/ i have vista 64 bit and i was thinking on runing a gadget or winamp or something like this on a small nokia 3310 lcd. (i guess you've seen such projects). the problem is, i don't have a serial port, so i can't do that. then i saw this forum. i really like all of your designs! they're awesome =D. could anyone make me a PCB and program the PIC? i would pay you
  19. error2061
    error2061 9800GX2 is dead long live 280GTX
    13 Jun 2008
    Works great for me in Vista x64 SP1
    :clap:
    The source code links would be most appreciated
    Keep the modding up
    EDIT:-
    I recently installed windows 7 (x64) beta
    if you follow the steps for a Vista x64 installation it works perfectly !! :clap:
  20. Anttifast
    Anttifast What's a Dremel?
    2 Jun 2008
    I just finished my controller.
    I had some troubles but I managed to solve them. =)
