Planning Makin a reservoir
Discussion in 'Modding' started by Sky_wolf, 11 May 2015.
  1. Sky_wolf
    Sky_wolf New Member
    5 Sep 2004
    I haw found a cardboard tub 4 mm thick. And i was thinking to yous "glazing" resin to water prof this.
    Will this be strong enough to handle this? :dremel:
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    If you were to use resin to waterproof the cardboard tube, why not just use the tube as a former, add slip, resin and glass fibres?
    Or if you just need a cheap res, a pvc pipe and end caps should do it..
  3. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
    Or buy a plexi tube. Or an aluminium one. They're cheap and can be modded easily.
  4. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    If you use the same resin as DIY boat builder use on their plywood boats you should be fine, although I agree with Nexxo a plexi tube would be far easier, unless you're planning a specific look.
