Electronics making a 50/60hz clock
Discussion in 'Modding' started by bixie_62, 19 Aug 2005.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey all
    am making a clock.....
    and ive managed to acquire an IC.
    the lm8560n
    i've got everything else wired up and everything,the only thing that i cant figure out is the 50/60hz input
    so is there anyway that i can make some sort of a small board that will output a 50/60hz signal?
    thanx.
    (im thinking 555 timer)
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    A 555 timer is not accurate enough - you'll probably end up losing or gaining several minutes every day. The IC is designed so that you can easily derive a stable frequency from the mains (hence the 50/60Hz signal), but if you can't for whatever reason then you either need a crystal-based oscillator, and scale down the frequency.
  3. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Did you have a look at the LM8560 datasheet...?
    All you need is a 100K resistor and a 1nF capacitor connected to the secondary winding of the transformer and the 50/60Hz input.
    CD :)
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    bUT HE'S Wanting to run it from a battery. Something like a 4060 chip, which has a built-in oscillator that can be crystal-controlled, and a built-in divide-by-2-lots-of-times series of flipflops, would be OK, but I can't spot a crystal frequency to give 50Hz or 60Hz after binary division. :confused:
    There is a battery-backup on that chip, so maybe it will keep reasonable time from built-in bits. :confused: :confused: RTFM. ;)
  5. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Sorry, I can't see where he's talking about battery running... :confused:
    3.2768MHz Xtal with 2^16 divider gives you exactly 50Hz.
    Intersil used to have a chip (ICM7238?) which runned from a 3.2768MHz Xtal and had two outputs (50 and 60Hz), but it seems obsolete now (I have still one running on a self-made LED clock from 1973).
    The 4521 unfortunately has 2^18 as lowest divider, the 4060 has 2^14 as highest divider.
    A 4060 with 3.2768MHz Xtal, output after the 14th flipflop, followed by two more flipflops to obtain 2^16 divider?
    CD :)
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Ah, it was his other thread on the same subject :eyebrow: , but as the datasheet circuit shows how to tap the 50/60Hz from the psu transformer secondary I assumed he was still on the same requirement. ;)
  7. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey
    thanx for that.
    yup, i do want to run it off a battery,but i dont particularly wanna mess around with AC power.
    will see whats happening after i get my results on thurs as will have more cash on that day if all goes well so will probly end up placing a big order with RS on fri!
    thanx all.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Don't forget an LCD clock will run a year on a small battery, an LED one a few days. :sigh:
  9. SteveyG
    23 Nov 2002
    And maybe not even that if your segment current is 10mA... :(
