Features Making Corsair Dominator Platinum RGB Actually Platinum
Discussion in 'Article Discussion' started by bit-tech, 7 Aug 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    *Farms out the plating*
    Dude. :( I thought you would show us how to set up dip vats. I guess if acids are illegal you can't.
  3. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    I mentioned this on the youtube channel, but once you discovered what the material was did you try any traditional paint stripper products
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I don't believe so, but @Maki role will know for sure
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    There are home electroplating kits that work with some degree of success (like any coating/plating job its only as good as your surface prep), but for a one-off they probably cost more than getting it done professionally.
    Arboreal likes this.
  6. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    Great video, thank you !
Tags: Add Tags
