Guide Making Custom Thumbscrews
Discussion in 'Modding' started by mattthegamer463, 7 Feb 2007.
  1. mattthegamer463
    26 Nov 2004
    Disclaimer; I totally ripped off the guide on metkumods with their idea of making custom thumbscrews and using dice for them, but I found this one at school today and remembered the mod and just had to try it myself.
    Tools needed:
    - Drill
    - Strong adhesive (epoxy or superglue)
    - Clamp or vice grip
    Items needed for mod:
    ^ Object to mount screw into (in this case a dice) and a standard case screw.
    Step 1:
    Place object in a vice or just hold it if you can.
    Step 2:
    Drill shallow hole into the item. I got the idea of using the 1 dotted side of the dice because then theres a perfect hole in the middle so your hole will be smack in the middle, and theres no surrounding holes to partially drill out.
    Fits perfectly!
    Step 3:
    Put glue into the hole and put in the end of the screw, clamp in place until the glue dries.
    All done!
    Works!
    Doing this is a great and cheap way to make custom or novelty thumbscrews. Its also so simple and straightforward that writing a guide is almost redundant. Enjoy!
    EDIT: Ripped off article here: MetkuMods- Theme Screws
  2. bamboo
    bamboo What's a Dremel?
    4 Nov 2006
    Look very nice, mattthegamer463. :thumb:
  3. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Looks very nice!
    Simply but nice mod!
  4. Kurayamino
    Kurayamino As long as the Raven flies
    5 Sep 2005
    Cool! Never thought of that! Nice One!
  5. calib3r
    calib3r What's a Dremel?
    11 Jul 2006
    I have to try that some day.
  6. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    Step 1) put a hole in the dice
    Step 2) put your junk in the dice
    Step 3)make her open the dice install dice on computer
    :cooldude:
  7. mattthegamer463
    26 Nov 2004
    Glad everyone likes it :)
  8. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    ROFL this is funny. i find it commical to put a dice on a screw on your case haha. unless your case is a boardgame, i dont think it would be very good however it is a novel idea. i can use this for other things =D
    ta
  9. IAmATeaf
    IAmATeaf Minimodder
    9 Jun 2006
    Thanks to this guide I can now have a dice on my PC to go with my hanging dice in my car :)
    Seriously, nice and easy guide and I was surprised by how the end result turned out.
  10. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    actually this can also be ued to make round generic thumbscrews, by using a lathe, grinder, or drill press to rotate the screw shaft and sand down the dice (the color of which is chosen previously); and you have an instant colored plastic thumbscrew.
    mix with dice of theme color for best effect.
    for those with a lathe this can be used to create some awesome designer thumbscrews.
  11. morris8809
    morris8809 Minimodder
    30 Dec 2006
    i made some of these for my white and blue themed case and they are friggin sweet. Although i did strip out one of the screw holes cuz i over tightened it... Any body know of an easy fix for this?
  12. Bluephoenix
    3 Dec 2006
    go to a hardware shop and get a thread tap and a new screw for the tap thread size.
    the hole will be slightly larger (so will the screw size, but when it's on it shouldn't be noticable.
    to avoid trying to put the new screw somwhere else if you disassemble the case, try and get a colored screw.
  13. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    ** its a die ** :p (plural is dice)
  14. mattthegamer463
    26 Nov 2004
    Yes I was aware at the time but the word die can be confusing to the lesser educated ranks of society. Its similar to the debate of aluminium vs aluminum, and even though we all know we are wrong, we still like our way.
  15. cr3ativ3
    cr3ativ3 What's a Dremel?
    24 Apr 2007
    nice guide, quite simple, but usefull to those who want their own "touch" in their mod :rock:
    as i saw above written, i'll try that soon too! :)
    regards
  16. Jodiuh
    Jodiuh What's a Dremel?
    17 Mar 2006
    That's awesome and cudos to bt staff for runnin' through the forums for us!
  17. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Nice guide ;)
    Might try it myself :)
  18. pendragon
    pendragon I pickle they
    14 May 2004
    this is pretty freak'n cool! thanks!
