I think this is the right forum for this. Anyway, here goes... I've been trying to burn some avi files to DVD, and can't seem to get it right. So far, I have just tried with the Nero thingie that does it (I know, so technical). But, all of the DVDs I have tried to make this way just end up having audio sync problems. I'm not sure if it the software, or a glitch with my burner, but the first one I tried, the audio was OK for the first half of the movie. Then, all of a sudden, it jumped and was off by about a second. So, the question is, what do you guys use for this, and have any of you experienced the same problem? Thanks in advance guys.
Easiest thing to use is DVD Santa in my opinion. Or AVI2DVD which can actually give better results as you can use better encoders like CCE, which you have to pay for seperately. There are other encoders available free but none which come close to CCE. DVD santa is the quick and easy way.
