Modding Making holes in steel
Discussion in 'Modding' started by bard, 10 Apr 2003.
  1. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Making holes in steel is in general not hard, but it tends to get harder when you need holes that are somewhat bigger than your drill bits are. For my case which I am building at the moment, I need a hole in my steel bezel with a diameter of approximately 23 millimetres. How would you recommend doing this? I have a router, and I know there are special bits for routing in metal, but I have noticed that router bits tend to be quite rough on the old pocket book. So I need some alternative ghetto solution or something. I could, on such a large hole, maybe use the jigsaw with a fine toothed narrow blade, but it it is not narrow enough, it'll just flex and cut outside of the hole. Is it possible to drill a center hole, and then use one of those weird "sanding-sticks" that came with the dremel?
  2. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    I would draw out the circle needed and using a 2mm or 3mm drill bit, drill a succession of holes 1mm apart around the inside of the circle. Either use pliers, snipers, or the same drill and remove the material between the holes. Then you can use a sanding ring attachment on the dremel to tidy it up. This is how I enlarged the hole for my reset button on my PC-70 front panel.
  3. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
  4. kong
    kong cnc-guy
    24 Feb 2002
    What Hippo said, you can buy individual hole saws in B&Q, get the hole saw for about £4, and the arbour for it is about the same. Obviously once you have the arbour, you can buy various size holesaws for your needs.
  5. bard
    8 Mar 2003
    That would be cool, hippo, but I'm already over the budget...
  6. DJMyst
    DJMyst yeah baby
    18 Jul 2002
    I think ouija's idea is the best to go with so you dont have to buy any new tools. you could make the individual holes and then use the cutting bit on a dremel to make it a complete hole and then sanding ring to tidy it up. Sounds like a winner to me at least. :D
  7. ouija
    10 Nov 2002
    I do have holesaws but on a hole this small, I wouldn't use one. Mainly because without some way of clamping the material down and lowering the drill onto it, it tends to wobble slightly. Even if you cut from the inside, you still have some tidying to do. The arbours I have used have two prongs which hold the saw in place, but not correctly and it often wobbles. I removed these and tightened the saw further down the thread, but now it's so tight I need vice grips to remove it :)
  8. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    this may sound stupid but I paid a ton of cash for my 80 and 121mm hole saws... the idea of trying to cut through steel with them makes me cringe. I have some cheaper smaller ones that would probably suit the needs of this size. I usually use them on softer materials like wood, acrylic... but I'm lazy too, and if it came down to dremeling and filing a hole or using the hole saw I'd be in a real perdicament... :hehe:
  9. ouija
    10 Nov 2002
    I made my 80mm (well... 76mm) holesaw blunt by cutting holes in my dad's steel case... and my mate's.... now all it does it shred the aluminium when I try to drill it.. :confused:
  10. eddie_dane
    31 Jan 2002
    I'm glad you told me that because I thought I may be baby-ing my hole-saws... *cuddles them and talks in schmoopie voice* "Only aluminum/plastic/wood for you..."
  11. kong
    kong cnc-guy
    24 Feb 2002
    Fair comments guys, I remember whe nI bought a cheapy hole saw set, and the first time I tried to go through light steel, all I succeeded in doing was grinding the teeth off' the saw! However, if you go slow, and don't let the saw or the piece heat up too much, there shouldn't be any problems. And as for wobble, well hey, I successfully cut my cd-rom drive button from 8mm copper bar using a holesaw and arbour with the pilot drill removed.
  12. ouija
    10 Nov 2002
    ROFL :lol:
    "Never exceed the cutting speed for the material you are cutting"
    How to determine the speed at which to cut
    I use "eclipse" holesaws from Maplin and CPC, they are very good and so quick to cut when they are sharp/new.
  13. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    Has to be done very slowly with a big tool :)
    Lubrication helps as well.. - honest.
  14. Oclocker
    21 Jun 2001
    Does it have to be 23mm exactly - hole saw would be cheapest option - but not brilliant at that size - very good is a hole punch - not that dear and usually does a brilliant hole - best way is a cone drill bit or a stepped drill - I use these and fantastic.. But not exactly cheap..
  15. ouija
    10 Nov 2002
    Excuse me???? :worried:
  16. Oclocker
    21 Jun 2001
    Ya did it too fast - and not with a lubricated bit?
  17. ouija
    10 Nov 2002
    Obviously, the joke was wasted on you :)
    Re-read what you said about the tool size.. and lubrication :thumb:
  18. cderalow
    cderalow bondage master!
    23 Jan 2002
    i think ouija just has a sick mind.....
  19. Oclocker
    21 Jun 2001
    Well he is a fifer :)
  20. Oclocker
    21 Jun 2001
    Erm it was my joke get ya own :)
    ooeer missus!!
