Electronics Making irDa header setup for motherboard/connecting to phone
Discussion in 'Modding' started by cderalow, 28 Feb 2003.
  1. cderalow
    cderalow bondage master!
    23 Jan 2002
    I want to make a irda setup for my pc so i connect with my cell phone and need a lsit of parts, and a schematic to go off of...
    my mb has the following pin setup:
    Pin 1: VCC
    Pin 2: NC
    Pin 3: IRRX
    Pin 4: GND
    Pin 5: IRTX
    so basically i need to know what I need to make one, how to make it, and then how to wire it to my motherboard
    thanks for any help
  2. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    Have a look at my site and click the IrDA button. Then go to IrDA explained.
    I think I'll put it up on the mod guides board.
    You need to look at your manual to work out the pin configuration and set your BIOS to use IrDA.
    Meblin
  3. cderalow
    23 Jan 2002
    hrmmm might buy one just to keep from having to find everything.... I presume you make them for that cost? and is it possible to tell me what wires correspond to what using the pin setup I listed above?
    also.... where do I send money (as I just ordered one)
  4. Meblin
    5 Mar 2002
    I will send you my PayPal details.
    I will create a header that will fit onto your motherboard correctly.
    Is 1m long enough for your cable?
    Meblin
  5. cderalow
    23 Jan 2002
    yeah.. should be plenty
