Windows Malwarebytes blocked just about everything
Discussion in 'Software' started by GregTheRotter, 6 Jun 2011.
  1. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Ok, so I wanted to download something with utorrent. Before, I'd get speeds in the hundred k, now I get speeds of 20kb, wtf. I never got trojans from other ip's etc , but mb seems to block every port under the sun and I can't download for shiz. Any ideas? If I close mb, do the blocks it was doing cease to exist? Or do I have to remove mb entirely? Any help?
  2. Deders
    Deders Modder
    14 Nov 2010
    Utorrent should only use 1 port, who's your ISP? sometimes they slow your internet down at certain times if you download too much.
  3. GregTheRotter
    9 Aug 2008
    What I meant to say is that it's blocked LOADS of ip's that it thinks aren't safe. How are you supposed to download anything :(
  4. brighty22
    brighty22 What's a Dremel?
    19 Aug 2010
    I think its possible to switch off the protection module which blocks connections even when mb isn't running.. try disabling that. I think it runs independently and checks everything.. so you might have to permanently disable it if you use bittorrent on the same computer. Having said that, those IP addresses must be blacklisted for a reason :/
  5. GregTheRotter
    9 Aug 2008
    Bah, this's bs.
