Man....I can't decide - 3700x or 9700k?
Discussion in 'Hardware' started by Neilc, 18 Aug 2019.
  1. Neilc
    Neilc Minimodder
    5 Apr 2011
    I only play games with a 1080gtx at 3440 x 1440, so generally always GPU bound - and don't really do fast shooters so not fussed about the highest possible frame rates.
    Thats about the only thing that stresses my computer, don't need loads of cores for compiling/rendering or anything of that kind.
    I'm ordering tomorrow, and have thinking to go with the 3700x, but I've always built with intel, and man it's feeling strange to jump to the red team - please someone tell what I should do?????
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    If you're not fussed about FPS and you're not a heavy (CPU) user then I'd say the decision is simple: whichever is the cheapest combo (CPU, Motherboard, RAM, Cooler).
    EDIT: here's a question: do you or will you overclock?
  3. Neilc
    Neilc Minimodder
    5 Apr 2011
    Well there is £1 difference between the 2 combo's!
    I wouldn't overclock the AMD chip as most youtubers have said not much point. I would overclock the intel cpu, as thats part of the fun I guess.
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    and what would your future plans be? You're upgrading now, when would you upgrade in the future?
    Neilc likes this.
  5. Neilc
    Neilc Minimodder
    5 Apr 2011
    Good question - won't plan on upgrading for another 3 - 4 years, Will upgrade the GPU in a couple of years I would think.
  6. yuusou
    yuusou Multimodder
    5 Nov 2006
    Then I'd say get a 3800X.
    Neilc likes this.
  7. David
    7 Apr 2009
    If I was upgrading to a new platform, I'd go for X570 Zen 2.
    Neilc likes this.
  8. wolfticket
    19 Apr 2008
    This is a classic Bit-Tech answer :grin:
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Personally for the last few years I have leaned toward power consumption and noise, which in turn is related to heat. Therefore I have stuck with Intel so far for those reasons. I don't overclock and game little but have been thinking about Ryzen for my main rig (currently an i7-8700) which is used for work, browsing and occasional DVD ripping/handbrake etc.
    The only thing stopping me is how much it would cost me to change from my current main rig to AMD, plus the fact that more power consumption equals more heat therefore more noise - I am a bit of a silence junky.
    Given you are on Haswell (going by your sig), upgrading to Intel or AMD will give you a performance boost either way, so it really boils down to cost IMHO.
    Neilc likes this.
  10. adidan
    25 Mar 2009
    You see i've been mulling that over but i'm leaning more towards a 3600/3700X and B450 and switching up to AM5/DDR5/Pci-e 5.0 on the presumption they'll all happen together in a few years(?)
    Plus also, cheapskate.
    Edit: But yeah, the X570 (it is an x570 bundle right?) gives you more options over the next couple of years @Neilc , and if it's a gpu upgrade in that period at least it has you covered for pci-e 4.0 (no idea when we'll see a 4.0 gpu but there has to be a reason it's included surely).
    Tricky though, you won't be disappointed with either. At 1440p you'll feel a gpu effect before one of those cpus feels it (hopefully not too soon as i want to hold onto my 1080 a while longer too :happy: )
    Neilc likes this.
  11. Neilc
    Neilc Minimodder
    5 Apr 2011
    ok thanks all for the help and advice - have gone with AMD :)
    Digi and adidan like this.
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Reminder:- If the motherboard is not X570, it'll need a BIOS update before it recognizes the CPU.
    adidan likes this.
  13. adidan
    25 Mar 2009
    Oh very much this.
    Unless the vendor has done it (or you get them to) or it's an MSI Max board (although I think only the Tomahawk Max is out at the moment).
  14. Neilc
    Neilc Minimodder
    5 Apr 2011
    Went with x570 so going to be fine. I wonder how many people got caught out by this?!
  15. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    It's happened enough for AMD to restart their old "Loaner CPU" program
