Equipment Manfrotto 055CXPRO3 HELP!
Discussion in 'Photography, Art & Design' started by thetrashcanman, 6 Jun 2013.
  1. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Okay so not entirely sure if anyone can help me with this, but basically have sold my Manfrotto tripod and I can't remove the 324RC2 head from the top of the tripod,
    and ITS DOING MY HEAD IN:wallbash:
    Anyone got any tips for removing the two? I've un-done the three screws underneath the bottom of the mounting plate but still no luck, I suspect with the pressure that has been applied to it, (the head hasn't been removed from the tripod for two years) its sort of just got itself stuck there.
    But yeah, any ideas of how to remove it? Before I start pulling my hair out
  2. October
    October Mariachi Style
    20 Jul 2009
    Lock the pan and twist like frig?
    Krikkit likes this.
  3. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
    the installation video shows them using a screwdriver in a small hole on the side of the bottom plate of the head and using that to tighten, can you use a decently strong and long steel screwdriver in that hole to loosen it?
  4. thetrashcanman
    18 Nov 2010
    Cheers for the answers guys, turns out I was being a complete tool, just need to hold it in a certain way and turn in a particular direction, thanks for the help though :thumb:
  5. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Well that no surprise Batman!!!! not the first time you have been a tool lol hahaha
    just kidding!
