A/V Manually upgrade sky hd box
Discussion in 'Tech Support' started by goldstar0011, 10 Jul 2013.
  1. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    My soon to be in laws have the non HD sky box, wondering if they can use my spare sky hd box.
    They don't want hd but was assuming they would get some improvement in connecting using hdmi over scart at the moment.
    Cheers
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I recently upgraded my non-hd plus box with a HD+ box that I bought myself and there is a definite improvement.
    All you might have to do is get in touch with Sky and register your box with their card. They should also be able to recieve the Freeview HD channels so Channel 5 HD, BBC 1 & 2 HD e.t.c without the HD subscription.
  3. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Yeah as above should work fine. Exactly what I did when Dad got Sky to give him the 500GB box I got the older 320gb box. Quick ring to sky to add my card / box combo and about 15min all working fine. Think it was the Box serial and software version, and the card number they needed.
  4. goldstar0011
    2 Sep 2007
    Cheers
    2nd thing is, the sky box need a HDD, can I use the original drive (guess it'd lose the files when formatted) or even a different HDD?
  5. dynamis_dk
    23 Nov 2005
    Original will work fine, like you say once setup it will wipe it but it'll work fine and tbh likely give you the easiest path as the original one was picked by sky :p
    If you google the model there are already loads of tutorials on Sky HDD upgrades to help pick a good model. I to a 1TB drive in my first Sky+ box and it was just a random 1tb drive I wasn't using (think it was a pipeline series drive). Then you just go into the menus to do a format/setup on it. Remembered it takes a while for a big drive so do it before you plan to sit and watch anything
    From what I recall most HDD's will 'work' as it install and setup but a lot of models had firmwares which the sky box doesn't play with very well so it end up locking up the box and corrupting recordings so I'd recommend doing a spot of homework for the drive model most suited.
