Electronics maplin digital multimeters
Discussion in 'Modding' started by Shuriken, 23 Apr 2003.
  1. Shuriken
    Shuriken same christmas AV for a whole year
    1 Jan 2003
    finnally got me a digital multimeter.
    maplin are doing buy one get one free on a £4.99 one, plus, if u sign up to there mailing list u get £2 off. its not bad either, same as i use at college, claims 0.5% accuracy. just thought id tell you'll. i love cheap stuff :D
  2. andyunder
    andyunder What's a Dremel?
    22 Mar 2003
    me got my self two of them. at least if you blow the fuse in one you can use the other till you replace it:thumb:
  3. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    That's the same one as I've got, broke the leads though, I'm using hookup wire now :(
  4. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    also got one, i broke the leads too, so re soldered em :D
  5. Shuriken
    1 Jan 2003
    hmmm, get the feeling the leads break easy, oh well, at £2.50 each its all good
  6. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Yeah my leads broke too.... :( might just get a decent one one of these days insted of being tight...
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I got a Fluke 112... works great.. a bit more costy though.. but.. who cares? :rolleyes: :)
  8. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    I got a rapid electronics one, with a bar graph (just incase you forget how to read numbers), its auto rangeing which saves so much time.
  9. Smilodon
    25 Mar 2003
    actually.. that bargraph is iseful for something else... you kow.. if yo want to measure voltages that vary a lot... then the numbers might not be fast enough to measure everything... but the bargraph is way faster... :geek: :hehe:
