Electronics Maplin LCD Mounting any good??
Discussion in 'Modding' started by couzo, 12 May 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I have tried to cut my own lcd mounting but it went a bit wrong and I have a very bad temper so I ordered one of those LCD mounting bezels from maplin has anyone got one? If so how does it work I have the 2x20 does the bezel just replace your two existing 3.5 bay plates of what??
    Thanks in advance
    Couzo
  2. deedub
    deedub What's a Dremel?
    19 Apr 2002
    The mounting bezels from Maplin are packaged with 4 screws, a small
    clear acrylic window that fits into a recesed hole behind the bezel....
    and of course the black bezel itself. Your LCD will line up perfectly
    (as long as you get the 2x20 bezel:) )
    In other words you will still have to cut a hole in your case to mount the
    bezel and the LCD.
    You could try one of the drive-bay LCD mounts from Matrix Orbital here
    My Maplin LCD mount is pretty good, but if you want a quick fix......go for
    Matrix Orbital.:dude:
