Modding Maplins cathodes
Discussion in 'Modding' started by sboy, 15 Jun 2002.
  1. sboy
    sboy What's a Dremel?
    6 May 2002
    Hi can anyone point me in the right direction on how to wire these up? say some kind of guide perhaps
    and all the mappers codes for the stuff needed would be great as well if some one's got the time iv heard people say a t1 box is good to house the invertor? i dont know so if someone could help will be going to mappers tomorrow to get me new cathodes!!!
  2. sboy
    6 May 2002
    And jut so i dont get read the sticky the codes i need for maplins would be for any connectors, wires, box etc not for the actual cathodes and invertors
  3. dukebox_1st
    dukebox_1st What's a Dremel?
    26 Apr 2002
  4. sboy
    6 May 2002
  5. Fly
    Fly inter arma silent leges
    31 Aug 2001
  6. sboy
    6 May 2002
    The first link to the tubing i dead :sigh: and i still need to know how you have attached them to your case!!!
    have seen your piccies fly and its the look i want to achieve
  7. Fly
    31 Aug 2001
  8. sboy
    6 May 2002
    The picture on how you attached it are they just cable ties and a bit of foam backing mate
  9. Fly
    31 Aug 2001
    yep, black cable ties and cable tie mounts (SJ13)
  10. sboy
    6 May 2002
    One last q's fly can i get this type of box from maplins
    if so whats the number for it mate
  11. Fly
    31 Aug 2001
    here are some numbers for boxes...
    Maplin's boxes that fit that spec :
    SC80B Mini ABS 80x40x17 £1.29
    BZ72P ABS Box H2855 79x49x26 £1.69
    LH20W ABS Box MB1 76x58x36 £1.99
    KC92A T3 Box 75x51x25 £1.19
