Windows Mass Effect2 stuck in the wall/air troubles
Discussion in 'Gaming' started by Siwini, 1 May 2011.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    I am been trying to play Mass Effect 2, but the damn thing is almost unplayable and here is why. I'm constantly getting stuck in the mid air especially if I try to take cover behind walls. Literally pisses the crap out of me as I am trying pass on insane difficulty:wallbash: Not fun going back and loading your save files. I didn’t really have these problems when playing normal or even hard difficulty setting. I was looking forward to Mass Effect3, but if they don’t fix this sht I am not buying it. Its hard to believe that $50 game in this day and age would be so buggy and with so much glitch. Anyone else hard these similar issues?
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    AFAIK the only solution is to quick save often and reload whenever you get stuck. Kinda sucks :-\
  3. Pete J
    Pete J Employed scum
    28 Sep 2009
    Can't say I've ever had 'floating in mid air' problems - or any others for that matter. I've sometimes been able to climb onto things I shouldn't be able to but I've always managed to get back to ground level.
  4. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I never had that issue in the first or second, and i played both multiple times.
  5. bagman
    bagman Minimodder
    18 Apr 2009
    I have had that problem as well in normal difficulty but only happened twice luckily I could get down from the position I found myself in so I didn't have to redo any levels, but yeah really pissed me off as well
  6. Tangster
    23 May 2009
    Happened a couple of times, after which is edited the .ini file to give the "fly" options similar to ME1's console. Taking the console out for ME2 was irritating.
  7. snooky32
    snooky32 What's a Dremel?
    29 Apr 2010
    I had this issue 2 or 3 times during my first play through on normal, i'm playing it through again on hardcore atm and it hasnt happened yet.
