Question: Find the equation of the perpendicular bisector of the line joining (2, -5) and (-4, 3). Give your answer in the form ax + bx + c = 0. Answer: 3x - 4y - 1 = 0 I started by finding the midpoint of the line joining (2, -5) and (-4, 3): ( 1/2 (2+(-4) ) , 1/2 (-5+3)) = ( (1/2 * -2), (1/2 * -2) = (-1, -1) Then I found the gradient of the line which came out as -4/3 Then I used -1 / (-4/3) = 3/4 to find the line perpendicular to the other which goes through its midpoint: y - y1 = m (x - x1) y - -1 = 3/4 (x - -1) y + 1 = 3/4 (x + 1) ... ... It doesnt simplify to the correct answer! Anyone know whats wrong? is my method right? if so then it must be the working out so i can post more of it if needed
No, it does simplify properly. You just stopped too early, and in a different form. 4(y + 1) = 3(x + 1) 4y + 4 = 3x + 3 (4y + 4) - (4y + 4) = 3x + 3 - (4y - 4) 0 = 3x - 4y -1 (edit) Darn, beaten (/edit)
Ohh really? I just wasn't bothered to type it up but i did it on paper and it didn't Anyway im sure i must have made i mistake somewhere so ill just go and correct it Thanks
