Other Mathematical Puzzle
Discussion in 'General' started by Blogins, 5 Feb 2015.
  1. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Need to crack this code so any help much appreciated!
    The numbers on the left below are the original numbers, then those on the right were generated using a formula. What is that formula?
    001 / 70
    002 / 83
    003/ 37
    004 / 12
    005 / 25
    006 / 38
    007 / 51
    008 / 64
    009 / 77
    010 / 68
  2. ch424
    ch424 Design Warrior
    26 May 2004
    (((x+4)*13)+5)%97 is very close - I don't know how to get 37 and 68 though
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Bag of bingo balls.
  4. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    Are the starting zeroes on the left side significant?
    Are both sides decimal?
  5. wolfticket
    19 Apr 2008
    It has the feel of a lateral thinking type answer, rather than just maths. Why are the numbers on the left 3 digits?
  6. Blogins
    3 Aug 2010
    Thanks for the effort but it does have to be dead right! :thumb:
    Here's some more data I've grabbed today...
    210 / 82
    211 / 95
    212 / 11
    213 / 24
    214 / 37
    215 / 50
    216 / 63
    217 / 76
    218 / 89
    219 / 05
    220 / 93
  7. Blogins
    3 Aug 2010
    Right then code-breakers, I've found some examples of different numbers generating identical two digit numbers as below...
    003 / 37
    214 / 37
    133 / 39
    205 / 39
    131 / 13
    039 / 13
    In the right hands this might be the key to cracking the formula!
  8. elise_s1
    elise_s1 What's a Dremel?
    26 Jan 2015
    is it a strictly Mathematical formula or does it contain also functions like (rnd), (abs) or similar?
  9. Blogins
    3 Aug 2010
    All I know is that the two digit number is derived from the three digit number on the left.
  10. loftie
    loftie Modder
    14 Feb 2009
    After looking at it for a bit - my brain hurts.
    But, both sets of data have a section that is linear involving the number 13. Other things i've noticed if you include a hard limit at 97, then the 13 patter mostly sticks.
    001 / 70 (+13=83)
    002 / 83 (+13 = 96)
    003/ 37 (fubared number, but take 96 +13=12)
    004 / 12 (+13 = 25)
    005 / 25 (+13 = 38)
    006 / 38 (+13 = 51)
    007 / 51 (+13 = 64)
    008 / 64 (+13 = 77)
    009 / 77 (+13 = 90 - fubared)
    010 / 68 (no numbers after)
    210 / 82 (+13 = 95)
    211 / 95 (+13 = 11)
    212 / 11 (+13 = 24)
    213 / 24 (+13 = 37)
    214 / 37 (+13 = 50)
    215 / 50 (+13 = 63)
    216 / 63 (+13 = 76)
    217 / 76 (+13 = 89)
    218 / 89 (+13 = 05)
    219 / 05 (+13 = 18 fubared again)
    220 / 93 (no numbers after)
    This is what you get if you try to graph it - i bunched up the 200s so the graph isnt huge. [​IMG]
    Well that's what I've noticed so far, thought I'd share. Don't know if it's right, certainly not complete.
  11. Blogins
    3 Aug 2010
    Thanks Loftie! Shows there is a pattern so there is a hard and fast formula in there somewhere.
    Just figuring the bugger out!
  12. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    218/89 (+13 = 05). I see how the others would work, but this one doesn't add up.
  13. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    What's interesting to me is that the first numbers range from 001 to 220, yet the formula's output is always less than 100. Further interesting is that a number as low as 007 produces 51, but 215 produces 50, and when you get all the way up to 219 you get 05.
    Is there a data set where the formula produces a 3 digit number?
  14. Blogins
    3 Aug 2010
    No, it's always a two digit number generated.
    I'll have to get a more expansive data set up for some serious number crunching!
  15. loftie
    loftie Modder
    14 Feb 2009
    218 / 89 (+13 = 05) ceiling of 97
    so
    01,02,03,04,05,06,07,08,09,10,11,12,13
    90,91,92,93,94,95,96,97,01,02,03,04,05
    This is all guess work tbh. Those 3 numbers though just don't make sense to me, the first graph had me thinking it was going to be a quartic equation, the second one swung me on to the idea of asymmetric triangle wave, but then I'd expect the gradients to repeat. So i'm probably just overcomplicating things! :D
    Failing that, it spells VW... :hehe:
    Edit: Where did this mental nightmare come from blogins? :p
  16. elise_s1
    26 Jan 2015
    let's try to put things together:
    ceiling 97
    step 13 (read as x*13) for rightmost digit
    offset -22 for each middle digit increase
    some sort of boxcar function (range 97) with 003 as transition point
