Education maths - calculus
Discussion in 'General' started by weasal, 20 Sep 2007.
  1. weasal
    weasal What's a Dremel?
    22 Jul 2007
    i have a question that i have to do and as im not very good at the calculus part of the course i was wondering if someone could help me.
    the question is find the derivative of 4x^2 - 3x from first principles.
    i know what first principles is and i am just dont know how to answer the question. :confused:
    i know how to differentiate is normally but its just the working.
    any help would be awesome.:thumb:
  2. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    You could use the power rule - aX^n = anX^n-1, example the derivative of 2X^3 = 6X^2
    Or you could do the horribly long method (f(X+deltaX) - f(X)) / deltaX example of this:
    X^2 + 7X
    [(X + deltaX)(X + deltaX) + 7(X + deltaX)] - (X^2 + 7X) (all over deltaX but we don't care about that yet)
    X^2 + 2XdeltaX + deltaX^2 + 7X + 7deltaX - X^2 - 7X <-- notice in this step all terms that don't have a deltaX will cancel
    2XdeltaX + deltaX^2 + 7deltaX <-- remember how this is all divided by deltaX?
    your dirivitive (well, almost) = 2X + deltaX + 7
    Get rid of the last remaining deltaX by taking the limit as deltaX approaches 0 and the derivative is 2X + 7.
    L J
  3. Hells_Bliss
    Hells_Bliss What's a Dremel?
    6 Apr 2007
    I knew I hated calculus for a reason :p
  4. weasal
    22 Jul 2007
    do you have to worry about the value of deltaX?
  5. alastor
    alastor Minimodder
    6 Sep 2004
    The definition of the (f(X+deltaX) - f(X)) / deltaX method, which is derivation from first principles, applies as deltaX tends to zero, so as above, just remove all the deltaXs in the equation at the end as they are zero.
  6. weasal
    22 Jul 2007
    does someone just want to use the equation for the question to show me as im still slightly confused mainly by like what Colonel Sanders said under X^2+7X
  7. alastor
    alastor Minimodder
    6 Sep 2004
    Hope that's at least slightly clearer...
  8. weasal
    22 Jul 2007
    that helps loads to the point that i now understand it so thanks for the help:thumb:
  9. GoodBytes
    20 Jan 2007
    Trick to be good in Calculus:
    Calculus I: Practice, practice, and practice.
    Calculus II: Even more practice.
    Once you got it, you will be able to do anything that is thrown at you quiet easily.
  10. Colonel Sanders
    25 Jun 2002
    Alastor - nice image, how did you make it?
    L J
  11. alastor
    alastor Minimodder
    6 Sep 2004
    Made it using Microsoft Equation Editor in Word 2003, would have used Math in OpenOffice but didn't have it installed on that computer. The equation editor in Word 2007 is a lot better than in 2003 though, probably worth it if you do a lot of equation writing.
