Modding Matrix Orbital
Discussion in 'Modding' started by richman, 17 Sep 2003.
  1. richman
    richman What's a Dremel?
    17 Sep 2003
    Iam looking into buying a matrix orbital display, i would like this to be quite cheap but not too cheap but at the same time not too expensive. I would like a display where i could programme it to say some thing Custom E.G Project Slime "Display CPU Speed"
    If anyone knows of a display that has some of the good features and is also easy to install.
    If anyone can help me with the hunt for a display i would be more than welcome.
    Cheers
    Rich
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    ummmmm i think there is one you could :search: :D matrix orbitals are the best though :D
    welcome to the boards btw
  3. fump
    fump What's a Dremel?
    14 Aug 2003
    welcome and i suggest lcd smartie if u want a freeware lcd app (it can use a matrix orbital or a parrallel connected display.) use LCDC if u want 2 spend money on the app. me thinks that http://www.kustompcs.co.uk sell matrix orbitals with LCDC included. bout £50 mark
  4. CrimsonSky
    CrimsonSky What's a Dremel?
    26 Jun 2003
    Matrix Orbital is coming out with a 2x20 and a 4x20 display thats USB plug and play, has fan headers for fan control, GPO outputs for controling devices..etc...I have one and its just awesome...very easy to configure.
