Build Advice Matx build help. £1500 ish budget
Discussion in 'Hardware' started by ricickle, 10 Mar 2012.
  1. ricickle
    ricickle Reamer
    27 Mar 2008
    Not built a pc in a while. My last one had one of the first i7 chips and 2 gtx260's in sli.
    I'm after building a new one into an old lian li ao5 I modded years ago.
    Pc will primarily be used to gaming and listning to music. A ssd is a must
    Any advice would be apreciated
    Cheers
  2. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Have a search around this Hardware Forum there is loads of previous builds you can have a look at, if you want to buy one now.
    Personally wait a few weeks for the next major releases from Intel and Nvidia
    Nice Corrado.
  3. Uxon
    Uxon Minimodder
    14 Dec 2010
    Yep 'wait for ivy bridge and kepler' is basically the reply you'll get from everyone atm unless its an urgent build. :)
  4. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    if you wait for nvidia release in a few weeks then you could get a 680 for probs about £550
  5. ricickle
    ricickle Reamer
    27 Mar 2008
    No problem won't be building for another month anyway so I can wait.
    I said Matx but I totally forgot I can take a full tax motherboard in the lian li my bad.
    And cheers bennieboy sold that car a long time ago and now have a full wide arch carbon fiber supra :)
