Cases MATX lovers rejoice!!!
Discussion in 'Hardware' started by Tynecider, 24 Aug 2013.
  1. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
  2. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Ahhh i know my next case now.
  3. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Ha they admint its insanely big for an ITX case. ;P
    " You asked, we delivered. Prodigy M now features full compatibility with micro-ATX motherboards, all while maintaining the same compact dimensions as the original award-winning Prodigy. Featuring an all-new layout, Prodigy M is truly flexibility reimagined."
  4. nimbu
    nimbu Modder
    28 Nov 2002
    Ok a little bit of a necro i know but I just lost paitence waiting and went and bought one of these.
    I must say overal been a dream to build with. Generally oozes quality.
    My gripes so far
    If using an optical drive both of the top 120mm fans are unusable.
    SSD Vertical mounting arm doesnt allow fat SSD's in there
    The side panel with power and usb is the side you would need to remove if you want to open up and add something, so thats means every time you need to disconnect all the headers...
    Other than that, great case, and possibly the tidest build I have done in a long time.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    got pics?
