MATX Sandy Bridge boards?
Discussion in 'Feedback & Suggestions' started by ch424, 17 Feb 2011.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hi Bit-Tech!
    Are there any reviews of MATX Sandy Bridge boards in the works? I know there's the southbridge problem so manufacturers might not be willing to send samples out, but it'd be great to know if any of them are as good for overclocking as the full ATX ones :)
    Thanks!
    ch424
  2. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    We're not reviewing any Sandy Bridge stuff until the fixed boards start to appear and can be tested, but once the industry sorts itself out we'll do some micro-ATX boards for sure.
  3. ch424
    26 May 2004
    Great stuff, thanks :)
  4. Guest-23315
    Guest-23315 Guest
    I'd put a hefty bet that there will be some Asus RoG mATX board.
  5. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Rampage IV Gene?
