Scratch Build – In Progress mATX-Tower 19-sep Completed
Discussion in 'Project Logs' started by Waynio, 10 Sep 2015.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nonsense, I was tired & took it bad, was a fair comment & I broke my own rule of don't post when tired. :)
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Changed the name of the project.
    Should be getting the vinyl wrap today & the aluminium tomorrow.
    Got the vinyl wraps, the grey is quite a bit darker than expected but I like the look of it.
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Got the alu today & done the front & back panels, I'll have a proper session tomorrow.
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Top, sides & motherboard tray done.
    This left to do which I'll try to get done tomorrow.
  6. Cheapskate
    13 May 2007
    Cool!:D
    -and enough aluminum powder for a good thermite bomb again.
  7. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    Love your precision Waynio.
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol:
    Thanks. :)
    I used to make my 3mm holes 4mm allowing for slight inaccuracies, this time I'm doing 3mm & countersinking so precision has to be awesome this time, so far so good. :)
    Done the mid & bottom panels & HDD cage, just need to make the 6 HDD trays now.
    The HDD cage is 5 panels, 8 modding cubes & 24 cut, sanded, drilled & tapped square bars, pretty good day of modding today, unsure if I'll head back to it to do those final HDD trays today or not.
  9. Cheapskate
    13 May 2007
    I have to comment every day until you are done...Saturday? -Because fast log.
    I'm getting tired. This is a lot of commenting.:lol:
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol:, It's all done now, just need to countersink all holes, clean up edges throughout & apply vinyl wrap.
    Done the HDD trays, but the mount holes was in wrong orientation so only way around it was either drill extra holes or just cut the little handles off & spin them around, I did the latter.
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    The HDD case mounts to the bottom panel.
    First assemble to see how it all is.
    It has a few imperfections but I think it'll do.
    I'll dissemble over the next days to wrap it in vinyl.
  12. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Awesome update:thumb:
    Those Excaliburs must be sweet tools, I would like to have one like that.
    Nice design, great execution, as always:rock:
    WOW, that's a lot HDDs you will be mounting there.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks phinix, yeah the Excalibur scroll saws are pretty awesome.
    Usual amount of HDD's for me, 5 HDD & 1 SSD, well spaced though so takes up more room.
    Took it all apart & smoothed all the edges this morning.
    Just need to wash the panels & apply the vinyl & reassemble.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Applied the vinyl wrap & done another test fit.
    Not showing the sides until I have the mesh & window installed.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Put handles on to make mounting/unmounting the side panels & internal PSU cover easier, added the mesh & a window.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Posting this update from the freshly completed case, yaaay. :)
  17. Teelzebub
    27 Nov 2009
    Nice work, reminds me of a front door
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks & yeah I didn't put much imagination into the panel. :lol:
    Couple of in use shots.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Temps with a 24c room temp.
  20. Icelander
    Icelander Minimodder
    3 Mar 2015
    Well done Waynio...
