Case Mod - In Progress Maximum Security - FINISHED 11/20/2011!
Discussion in 'Project Logs' started by SXRguyinMA, 28 Jun 2011.
  1. Voyen
    Voyen What's a Dremel?
    17 Oct 2011
    Does the latch on the case actually work smoothly? Because I have this case, and it doesn't lock up when I close the panel. I can usually just open the panel without having to unlock it. Or do I just have bad luck?
    Also, how did you get the handle off the case at the top? I can get the panel off, but can only find one clip for the handle. Any help?
  2. SXRguyinMA
    SXRguyinMA What's a Dremel?
    28 Jun 2011
    I ended up not using the latch at all. I used a small magnet on the top corner of the door to hold it shut, workslike a charm :)
    For the handle you need to pull the plastic off then there's screws holding the metal handle itself to the top of the case. The plastic is a tad tricky to get off but it comes off :)
    yassarikhan786 likes this.
  3. Voyen
    17 Oct 2011
    I can only find one latch on the plastic part of the handle. =\ Can't seem to get it off. Can you post some pictures or something showing where the latches are?
  4. SXRguyinMA
    28 Jun 2011
    Sorry man I'm just now seeing this reply. I don't have any pictures other than what I've posted. Did you get it figured out?
