Motherboards Maximus IV Extreme-Z won't recognise memory
Discussion in 'Hardware' started by mattyh1995, 18 Feb 2012.
  1. mattyh1995
    mattyh1995 Minimodder
    1 Oct 2011
    As the title says, I got a Maximus IV Extreme-Z (Which has two bios chips). I updated the first bios chip to the latest 1004 version and now when I try to boot it up I get the error code 55 on my debug leds which means "No memory installed" (And there clearly is). Now, when I change back to chip two, on version 0206 I think, it boots fine with the same ram.
    Tried the USB bios flashback, tried resetting cmos and it won't even post on the first chip so I can't do anything other than that, can I?
    Any suggestions how to fix this would be greatly appreciated
  2. AoE
    AoE What's a Dremel?
    4 Oct 2011
    It may sound obvious, but have you tried changing with various RAM configurations from the ASUS manual? I know that sometimes if RAM is put in say DDR 3 & 1 SLOT this can happen
    Although I suspect your ram channels on the board may be damaged if not the ram it self but I doubt that?
  3. narwen
    narwen narwen
    6 Aug 2010
    I think there's a button on the motherboard you have to push to set up the ram. Has the new bios does not new what ram is installed.
  4. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Should the above advice not work, can your board flash the second BIOS directly back to the first? I know you said you've tried using USB but doing it directly may yield better results.
  5. bulldogjeff
    2 Mar 2010
    If the old bios is fine, i would go for a bad bios flash. Put it back the way it was , check it works ok then start again.
  6. mattyh1995
    1 Oct 2011
    Yeah I have, tried it with both sticks in each slot in every combination. The ram channels can't be damaged seeing as it works fine from the 2nd bios chip :/ This is really confusing me now.
  7. mattyh1995
    1 Oct 2011
    The MemOK! button? Tried that to no avial.
