Motherboards Maximus V Gene BIOS Issue
Discussion in 'Hardware' started by Cei, 29 May 2012.
  1. Cei
    Cei pew pew pew
    22 Mar 2008
    I've just installed my new Z77 Gene, and have run in to an issue with the BIOS.
    When I press F1 to enter setup, my display goes dark and nothing loads on screen (1920x1200), via the GTX 580.
    I can boot to Windows fine, and the board is working. However, I can't install my 2500K's iGPU (doesn't show up, assuming disabled?), and having a screen connected using the onboard HDMI doesn't work for the BIOS either.
    Any ideas? I'm thinking the BIOS is displaying at a resolution my screen doesn't like maybe?
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Its DEL to go into the EFI...
  3. Cei
    Cei pew pew pew
    22 Mar 2008
    If I hit the reset switch on the I/O panel, on the next boot it tells me to press F1 to enter setup, which is when I then get a black screen. Just tried with Del, and exactly the same thing, except at no point during boot is anything displayed (and it doesn't try to boot Windows either).
    Bizzarely, it all worked fine on the IV Gene-Z.
  4. Bloody_Pete
    11 Aug 2008
    On mine its DEL just after the beep (if yours goes beep) or just at the code readout hits A0. I found that it didn't detect my screens native res straight away though, but it did display...
  5. Cei
    Cei pew pew pew
    22 Mar 2008
    No beep! I'll try and time it with the code, but I have left it on the blank screen for 10mins before resetting...
    Nope, same result :( I don't have another screen to try it with, beyond maybe rustling up a DVI-HDMI cable for the 580 instead of my normal display so I can try my TV?
  6. Bloody_Pete
    11 Aug 2008
    Could try doing a BIOs update, see if that solves it. I found the auto update on the software wouldn't work, so download the file manually and use the update from file in the Asus tools to update painlessly :)
    Cei likes this.
  7. Cei
    Cei pew pew pew
    22 Mar 2008
    Cheers, will give that a try :) +rep for the help!
  8. Cei
    Cei pew pew pew
    22 Mar 2008
    Gosh darn it, newest BIOS had no effect. Where's Bindi when you need him!?!?!
  9. Bloody_Pete
    11 Aug 2008
    :( Well, its defiantly DEL to enter BIOs, aside from that I don't know. Do you see the Asus logo?
  10. Cei
    Cei pew pew pew
    22 Mar 2008
    I see literally nothing, just black (with backlight on) screen until I reach the Windows boot. If I've done a BIOS reset I see some text, and then nothing. Trying with the TV via HDMI now...
  11. Cei
    Cei pew pew pew
    22 Mar 2008
    AH GOT YOU, YOU *******!
    Apparently it doesn't like 1920x1200. However it is perfectly happy with 1920x1080.
  12. Bloody_Pete
    11 Aug 2008
    Very odd. Pull out your GPU, that should kick in the on-die GPU and use that...
