Case Mod - In Progress Mayhems - Silver Bullet - pure real silver coolant (not aurora)
Discussion in 'Project Logs' started by mayhem, 14 Oct 2015.
  1. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    Weve stripped down the case again due to some mistakes and replaced the front glass panel with a aluminium glass like fascia, we've also lifted it more forwards to give better air flow.
    Here you can see matt getting ready to fit the mayhems Havoc 360 into place that he has spray painted silver. We've also mounted the EK Res and pump combo to the rad.
    We then fitted back in the main board and placed all the wires behind the main board so it neatens every thing up. We've allso put back in the PSU shroud. We caught some of the paint work on the rad so that will need touching back up.
    Ive made some of my own rulers to measure up the Glass tubing on the laser cutter (cost was about £2.00)
    And Matt and my self cut some peace's to size and matt sanded the edges down
    Dont ask me what hes doing here but it does look painful ...
    Preparing for the first peace to go in.
  2. mayhem
    12 Sep 2008
    First peace of mayhems glass tubing fitted
    Second peace fitted (all from the same single peace so no waste)
  3. asura
    asura jack of all trades
    22 Apr 2009
    Glass tubing? Very smooth Mr. Mayhem, very smooth!
  4. mayhem
    12 Sep 2008
  5. xivlia
    xivlia What's a Dremel?
    22 Apr 2012
    arent you gonna have to top up the coolant every 6 months or so due to micro evaporation from the tubes and reservoir? this will have a higher maintenance cost than my Ducati ;)
  6. Cheapskate
    13 May 2007
    I'd tell you what he's doing in that pic, but for now, give him some privacy.
    -And someone typo'd their mean tag.:lol:
    @Xivlia - There shouldn't be much. The only place it could happen at is the O-rings...maybe.
  7. mayhem
    12 Sep 2008
    @xivlia Unlike like plastic tubes were using glass so less issues, Topping up is easy i have 5 ltrs of the stuff made all ready to go :), that should last in excess of a few years :)
    @Cheapskate :)
  8. BOBDBONE
    BOBDBONE Owner at BS Mods
    4 Feb 2009
    That is some crazy coolant!!
    This is going to look good. :rock:
  9. Guest-16
    Guest-16 Guest
    Seems awfully hostile or did I miss something??
  10. mayhem
    12 Sep 2008
    yeh you missed it lol. Edited too keep the peace lol
  11. mayhem
    12 Sep 2008
    Well a small accident happend we saw that the front panel was out by approx 2 mm so tried adjust it, in the process we bent it and its irrecoverable. Start again on the front panel, that's life.
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    were the glass tubes custom made, or from a science supply store?
  13. mayhem
    12 Sep 2008
  14. Teelzebub
    27 Nov 2009
    Isn't it just "Borosilicate Glass"? because that's been around a long time and used in Pyrex and science / medical glass stuff, in fact when I was a kid I remember people making little glass figures with a blow lamp from it lol.
    The glass supplier I use sell it for lamp work
    I was wondering in what way is yours different?
  15. mayhem
    12 Sep 2008
    Our glass is a pyrex brand and is hand blown into place and then re hardend in a kiln at 1700c . All the peaces at with in a 0.02mm -/+ spec. Im sure you can make your own if you wish and it will be nice to see more builds with glass.
    Pic below is nearly finished we still need to shave off a little glass on the long peace. (you can see the gpu is a little out)
  16. Guest-16
    Guest-16 Guest
    You know I wish In Win had made that bottom cover as standard for the 805, or, made the front a 360mm instead of 240/280. And fix the side panel mounts, but that's another story for another day.
    I was going to mount a similar DDC in the rear 120mm fan space.
  17. Teelzebub
    27 Nov 2009
    Those temps are mainly only possible with very expensive kilns not the type you would have at home, tbh I don't see the point in making my own glass tubes, but speaking of glass you should check out Dichoric glass there's some amazing colours in it if you could do the cooling fluids in those colours :thumb:
  18. mayhem
    12 Sep 2008
    Yeh we use a pro to help us out with the tubing. He has some amazing skills when it comes to glass bending. Ill look up that Dichoric glass. We've already had a look at some colour glass ourselves but as of yet were just seeing how the market reacts..
    Just had a Look wow you need deep pockets for that but would be an amazing mod.
  19. Teelzebub
    27 Nov 2009
    Yeah not cheap glass, I work with it quite a lot there's a few different types of it now.
    Amazing colour shifts in it though
  20. mayhem
    12 Sep 2008
    Nearly done just a few more tweaks need doing. Had to remove one of the glass bends as we found out that the CPU / GPU ports are 2mm out from each other so we had to use straight runs instead. Over all though we only used 2 peace of glass tubing. The real Silver metal Fluid look more silver in life but will have to do some better shots later on.
