Modding MAZE4 mod, and new comp goodness
Discussion in 'Modding' started by bee2643, 7 Sep 2003.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    finally got around to taking pics of my new setup
    P4 2.8GHz 800mhz FSB
    1GB PC3200 DDR RAM
    ASUS P4P800 (inspired by bT review ;))
    120GB SATA HDD
    and a DangerDen MAZE4 CPU block
    i drilled a small 5mm hole into the side of the poly top and flushly stuck in an led.
    connected IDE ribbon cable to the led pins and wired it to a molex. you can't see the ribbon wire, because thats the point, as its very discrete and runs along the side of the block and then sneaks over and behind the mobo.
    enjoy the eyecandy, w/ and without flash.
    any suggestions/comments?
  2. mushky
    mushky gimme snails
    24 Mar 2003
    looks nice.
    that kink in the outlet hose near the maze4 looks costly. maybe try to sort that out?
  3. bee2643
    7 Mar 2002
    lol
    looks rather good in that pic :D
    from other angles it looks worse
    i plan on fixing this by getting silicone tubing in the very near future, so long as i can find a local retailer:grr:
  4. mushky
    mushky gimme snails
    24 Mar 2003
    A suitably sized spring wrapped round the hose at that point might help. It could be a bit fiddly to get it on but worth it.
  5. bee2643
    7 Mar 2002
    yeh
    shes 3/8ID tubing forced over 1/2 barbs
    i think its a lost cause untill the tubing is replaced...
  6. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Looks good. I guess it was inspired by coolmiester's maze 3 mod?
    and yeah. that kink looks pretty bad.
  7. Guest-16
    Guest-16 Guest
    Looks nice, but 2 problems:
    1 - the kink in the tubing is not good
    2 - you have a dual channel Asus intel i865PE or i875P mobo. By the different colouration of the ram slots that are unfilled (blue and black) id say you arent utilising the dual DDR mode on your mobo as one of the sticks should be moved to an adjacently coloured slot.
  8. bee2643
    7 Mar 2002
    yea the kink will be fixed like i said when i can find better tubing :)
    as for the dual channel ram thing yea i realised that last week, see i've never used this technology before, so i didnt know when i installed it. now im just waiting for a moment when i am able to shutdown to fix it :D
  9. Guest-16
    Guest-16 Guest
    Just do it now ffs. Wont take 2 seconds. :rolleyes: :rolleyes: :lol:
  10. bee2643
    7 Mar 2002
    HAPPY?!!1
    lol
    now look what you did you made me go ghetto
  11. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    lol i think he meant make it dual channel :p
    couldn't you just use a longer bit of tubing, and so a wider curve to get rid of the kink?
  12. bee2643
    7 Mar 2002
    dual channel is fixed also
    i could use longer tubing yes, but when i redid the tubing this was all i had left
    its cheap 10cents/yard acrylic tubing anyways
  13. Spiral Architect
    Spiral Architect Cooked on Phonics
    4 Sep 2003
    That looks sweet.
  14. bee2643
    7 Mar 2002
    i must also add that the horribly large rounded IDE cable will be gone as soon as i can find a north american based reseller for those tiny IDE-SATA converters (help!?)
    the ide wires you see running up are power for my external LCD units, which also will be routed through the bottom when i get a new serial connection for my motherboard, and the P4 12v power cable will be braided next week (along with bl00 heatspreaders for my rams) and glowy acrylic footsteps
    mmm glowy
    i will also be recieving laser cut fan grills for my radiator and 2 LED fans, the design will be a surprise :eek:
