MBM temps, need help.
Discussion in 'Hardware' started by Toric, 7 Jul 2002.
  1. Toric
    Toric What's a Dremel?
    29 Jan 2002
    I couldn't figure a better forum to put this in, so it's here. My GeForce 3 Ti 200 has been crashing, only in Half Life, on average, about 5 - 10 minutes into play. I'm not sure if it's an over heating problem.
    Turning on MBM:
    sensor 1 reads 23 C
    sensor 2 reads 77 C
    sensor 3 reads 77 C
    I'm not even sure what those sensors are reading... it also seems sensor 2 and 3 are reading the same thing even though they're set up to read different board sensors... And I only have 3. the numbers havn't changed in the last 10 minutes either, so maybe i'm doing something all wrong, or my mobo can't read temps very well, i need help...
  2. cderalow
    cderalow bondage master!
    23 Jan 2002
    best guess sensor 1 is your mobo temp (low?) 2 & 3 look like CPU (VERY HIGH)... but i'm not sure as it depends on your mobo
  3. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    At the MBM5 site there is a section that will tell you what the sensors report for different motherboards.
    http://mbm.livewiredev.com/
    Scroll down the menu on the left to Board Info and pick your MOBO manufacturer.
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    wat are youre other system specs, such as mobo cpu and hsf...
    those temps are very very high indeed, as the second sensor is ussually for the cpu, making it run at 77 would not suprise me if it crashed...
  5. Trash Man
    Trash Man What's a Dremel?
    26 Mar 2002
    My old 1.4 Tbrid ran @72c with no problems at all :D
  6. Toric
    29 Jan 2002
    it's a Biostar M7MIA with a IMD 1.2 GHz. It's got a stock HSF. But I think MBM might be a little borked, no matter how long i've been running my computer, the sensors all still read 23, 77, and 77. They never change! Oh well.
  7. Trash Man
    26 Mar 2002
    if they never changed then you prolly have not got it setup right m8.
